Re: Desktop not booting up! need help!
at this stage cannot say exact problem.. u need to check one by one..
ram,cpu,harddisk,pci cards remove all these components and clean them (also motherboard) and re connect it..
or it could be BIOS problem also, may be corrupted. need to flash (last option).
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
