Re: Suggest casing with eSATA + USB for 3.5" HDD
1. Power adapter comes with the casing.
2. Y cables are not meant for powering 3.5" HDDs.
3. Depends..there are a lot of good Chinese casings but they cost a decent amount too..unlike the cheap ones...
4. PATA connection only with PATA Casing...SATA only with SATA unless you buy something of this sort:
For details you may check:
http://www.scythe-usa.com/product/ac...scupc1000.html
If you need both USB and eSATA then you can also consider the HDD docking stations like:
The docking stations are much better than the regular casing (IMHO) in case it is supposed to be kept at one place...and it can handle both 2.5" as well as 3.5" HDDs.
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
