Old 20-05-2010, 10:50 AM   #1 (permalink)
laborare est orare
Cilus's Avatar
Default Motherboard for Phenom II X6
Guys, currently I'm using Gigabyte 785GUD2H motherboard with Phenom II 955. I am planning for a series of upgrades and the 1st step will be the motherboard and the 2nd one will be Phenom II X6
I need mobo with
1. new AMD 8XX series chip-set.
2. Crossfire support
Suggest something within 7.5k. I have short-listed two boards.
a) ECS 890GXM-A @ 7.5k ( 3 way Crossfire)
b)
ECS A885GM-A2 @ 4.9k (Crossfire in X8 mode)
Please share your suggestions with me.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now   Reply With Quote
Old 20-05-2010, 11:22 AM   #2 (permalink)
Default Re: Motherboard for Phenom II X6
I need mobo with
b)
why not: Biostar TA890FXE. its based on the 890FX & should provide optimum overclock & PCI lanes for crossfire & its price should fall within 7.5k too.
heres the link to the motherboard.
its crossfire setting is at x16,x16, x4, x1. so Crossfire possible, even with such bad placement of PCIe X 16 slots (what was Biostar thinking?).
Original price is 149.99$ so, should expect it below 7.5k.
Old 20-05-2010, 04:59 PM   #3 (permalink)
The Sorcerer's Avatar
Your board (all rev versions) are compatible with x6 processors: http://www.gigabyte.com.tw/Products/...ProductID=3156
There is no worthy performance boost between the 2 chipsets.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 20-05-2010, 05:26 PM   #4 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
you can save your 7.5k with a Bios update.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 21-05-2010, 09:48 AM   #5 (permalink)
laborare est orare
Cilus's Avatar
Guys, I know BIOS update will do the job. But the thing is 785G will only support Phenom II X6, but the advance features of the processor will be out of my reach then.
I mentioned I need Crossfire also and my current one is having single X16 slot.
Now the ECS 885G A2 is available @ 4.9k and I find it as an attractive deal. It will support all the advance features of Phenom II X6, having 2 PCI Express X16 slot for Crossfire, and all the candy SATA 3 and USB 3. But I didn't find any review on this till now
Could you guys enlighten me about this ECS 885 motherboard?
Old 21-05-2010, 09:55 AM   #6 (permalink)
Wise Old Ghoul
Piyush's Avatar
can u rank ECS along with other brands??
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 25-05-2010, 05:30 PM   #7 (permalink)
The word that you should is cheap. But you're loosing a lot for that.
In that case, here's a rundown.
The board uses 8 pin aux connector so that it can supply adequate power to the processor. But if you look at the board, the board has some crappy VRM and MOSFET with no passive heatsink over it. The main caps are only for the CPU and the rest of the board relies on electrolytic capacitors- yikes. If I do more digging, I will find more flaws. But if I were you, I would save more money and then make a worthy upgrade. The hexa core isn't going to run anywhere.
Hardware BBQ
Old 25-05-2010, 05:40 PM   #8 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
MSI 890GXM-G65 @ 7.5k
Old 25-05-2010, 06:18 PM   #9 (permalink)
pulsar_swift's Avatar
Hmm then ECS board @4.9K is not good. bro could you give the link for the review of this board
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
pulsar_swift is offline   Reply With Quote
Old 25-05-2010, 10:03 PM   #10 (permalink)
^^ There are no reviews AFAIK. The points I found and said are simply by taking a small glance of the photo from the company's website and if you look at it, most of the specifications mentioned there are false/vague. Think about it, do you REALLY think that a company will give a review sample to honest reviewers and expect a thumbs up? If a company hires a writer or tempts an infamous/famous hardware site/magazine for ad revenue, that's a different case.
Cant buy a decent enough hardware, don't spend at all. Do justice to your money. FYI, an AMD system with DDR2 1066mhz and another system with 1600mhz DDR3 makes little or no boost. The OP (and others who are curious) should check out the benchmarks I put up of 880GMA, 890GPA and 790FXTA in comparison with 790GXBE (which is a DDR2 board) in digit's review section.
Hardware BBQ
Old 16-07-2010, 08:10 PM   #11 (permalink)
Hi,
have you upgrade your system, if yes then please let us know the detail including price of each product.
Thanks
Bhupesh
bkarankar is offline   Reply With Quote
Old 16-07-2010, 08:11 PM   #12 (permalink)
he didnt upgrade
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
