19-05-2010, 02:30 PM
Can I get pc for 20k with following specifications
Hi ,I am Raj.I don't have great knowledge in pc hardware.
But I need pc with following specifications.
Processor : intel core 2 quad or equivalent.
mobo : Anything that supports above.
Ram : 4Gb
HDD : 1TB
PSU and Cabin.
I play games but not serious gamer , so i think on-board graphics is enough for me.
My budget is 20k and may be expecting too much in this budget.
Please someone give me proper guidance in buying a new pc.
19-05-2010, 02:50 PM
Re: Can I get pc for 20k with following specifications
Processor : intel core 2 quad or equivalent. - Q8300 @7.1K
mobo : Anything that supports above. - Gigabyte G41ME-S2L - 3K
Ram : 4Gb - DDR3 Hynix/Dynet - 4.8K
HDD : 1TB - SG/WD - 3.8K
PSU and Cabin. - Any cheap one/Zebronics - 1.5K
TOTAL: 20200/=
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
19-05-2010, 03:22 PM
Ram : 4Gb
HDD : 1TB
PSU and Cabin.
you can go with the config you choose (static X already provided pricing) however G41 worst when it comes to gaming. or go for these:
Athlon II X4 630 2.8GHz @ 4.5k
Biostar TA890GXE @ 6.5k (graphics powered by 890GX with 128Mb inbuilt memory)
Transcend 2X2GB DDR3 1333MHz @ 5.5k
Western Digital Caviar Green 1TB @ 3.5k
FSP Saga II 400 Watts @ 2k
Cooler Master Elite 310 @ 1.5k
total: 23.5k. street pricing should be a bit less. or go for Biostar TA785G3 HD (graphics based on 785G with 128Mb inbuilt memory) @ 4k. & total pricing will be at 21k.
19-05-2010, 05:54 PM
15.0 GHz
+1
But avoid Transcend products, instead go for Kingston Value series.
19-05-2010, 06:13 PM
Originally Posted by Varad Dilip Choudhari
+1
well yes. Kingston cost same. so switch to Kingston.
19-05-2010, 08:26 PM
BLUE IS THE COLOUR
Ram : 4Gb
HDD : 1TB
PSU and Cabin.
If you are not in to gaming and opting for IGP, you dont need 4gb ram now.
Your config is here
phenom II X4 925 @ 7k
Biostar TA785G3 HD @ 4.1k
Kingston 2GB DDR3 1333 @ 2.6k
Seagate 1TB HDD @ 4.2k
Gigabyte APFC 460W @2.2k
Total 21.6k This mobo got IGP HD 4200 with 128MB side port memory.More than enough for casual gaming.
You can cut it down by selecting Athlon II X4 630 @4.7k and going for 500GB HDD @ 2.1k
In that case you are getting a powerful rig @ 17.2k
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
19-05-2010, 09:51 PM
I would suggest the ajai5777's config with slight changes:
Radeon HD 4670 1GB DDR3 @ 4.2k
total 23.5. If you can't stretch your budget that much, you can take a cheaper motherboard & 500 GB HDD. Onboard GPU's are not good enough for today's games. Also, these days it is better to have a graphics card in the system as many applications utilize them and overall performance is improved. HD movies etc. run smoothly and you wouldn't find too much the lack of detail in games with this GPU. The PSU will be able to handle this card easily, I suggest you go for the GPU & you won't regret it.
As far as Intel is concerned, it's not possible in your budget. This system (if you buy the GPU) will be quite powerful.
19-05-2010, 10:09 PM
BLUE IS THE COLOUR
He dont need a Graphics card.Casual gaming and HD movies can be easily handled by IGP HD 4200 with 128MB side port memory.
It can run Full HD movies with ease.
19-05-2010, 10:12 PM
I'd suggest stretch your budget a bit and get a Core i3 based system with DDR3 RAM as in future DDR2 is going to get expensive and your future upgrade options will be wider...
A day without laughter is a day wasted.-Charlie Chaplin.
19-05-2010, 10:37 PM
core i3 sucks. stay away from it. cost like hell & delivers nothing. & when next year new processors no more support the H55/H57 motherboard, Core i3 fans will be first & last to regret.
i totally agree. a midlevel processor + a entry level graphics card much better than a fast proccy + IGP. processor will pull in 1 direction & IGP on other direction.
only for now. soon he'll need even better graphics. a gamer is always a gamer & will game
