Re: Motherboard for 26" monitor
The name of the thread should be Graphics Card for 26" monitor.
Running a 26" monitor, Graphics card is the most important thing, not the motherboard.
HD 5450 will serve good for watching HD contents on this monitor, but just forget about gaming. For this get HD 5670 1 GB minimum, but recommended is HD 5770 1 GB.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
