Re: Asus M2N MX Se Plus+Memory upgrade
Your question is not clear. Mention whether the Ram slot stopped working or the Ram, plugged into it, stopped working.
But the basic thing is you cannot use an ADM Phenom X3 8400 processor with DDR3 mobo or memory. It does not support it. The DDR3 motherboards from AMD are having AM3 socket type to plug new Athlon II and Phenom II series processors. They are having 938 pin configuration, where your CPU is AM2, having 940 pin. So even physically you cannot plug it to a DDR3 AM3 motherboard.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
