17-05-2010, 06:50 AM
External HDD & Pen drive
After having good & bad experiences with various companies as regards after sales service, I thought why not ask before buying. I'll be buying an external HDD (I'm thinking 320 or 500GB). I am not going for transcend in any case. So I thought about seagate. Anyone with comments on seagate's after sales service?
Also suggest a good (fast) pen drive of 8 GB. Kingston data traveller G2 which is the most easily available is not very fast I suppose. So, any suggestions? (Once again, I'm in no way buying a transcend).
If you want to know the reason for my aversion to transcend, read this: Stay away from Transcend pen drives
One more question, what is the full form of RMA?
17-05-2010, 12:03 PM
Re: External HDD & Pen drive
Seagate FreeAgent is a very good choice I prefer it over other brands. The seagate service is really good also.
You can also consider Western Digital ones I have heard that there service is very good but haven't experienced it myself.
For pendrive Go for Corsair Flash Voyager GTR they are really fast.
RMA is service provided by companies to get you a replacement of your under warrenty HDD.
17-05-2010, 01:55 PM
I just purchased a new seagate 500GB free agent go !!!!!!
Very good HDD comes with loaded software like movie maker,encryption etc
looks really cool as compared to WD
Price diff between seagate and WD is only Rs100
I got mine for Rs 4.2k
22-05-2010, 04:33 PM
enquired in the market today, seagate 500 GB is Rs. 4000 & 320 GB for 3100.
Since portability is not that important to me, I thought I'd buy a 500 GB 3.5inch internal HDD and a case. Would it be a good option? Does using a case void warranty?
23-05-2010, 09:42 PM
OK, can someone please tell me if a case necessarily requires an external power adapter or there are options with 2 USB cables?
Also, is it safe to use a hard drive fitted in this type of case for extended period of time continuously? (Like downloading directly into it using uTorrent for 3-4 hours every day)
23-05-2010, 11:12 PM
Most of external casing will have a separate power adapter. The 2 USB cables which you're saying is too weak to power such a big HDD. Using it 2-3 hours is completely safe. Just make sure you take care while transporting it as being an internal HDD they are not made rugged to absorb shocks & bumps.
24-05-2010, 05:27 AM
I read something about case with built in fans, are they available in India? It would be really nice as the reviewer had written it keeps the HDD very cool.
24-05-2010, 09:56 AM
New Gen Guru
yaah cases with fans r available from long back...I have a tech-com case which i bought 4 years back have a fan
Photography Gears -
Nikon D3100+18-55+55-200+50mm+55mmMicro,
Bag-Tamrac Velocity 6x Bag, Lowelpro pro Runner 200 AW
Yougnou YN-465 flash , Vanguard ESPOD 203AP,
http://500px.com/sujoyp
My flicker link -> http://www.flickr.com/photos/34748095@N07/
Desktop - i3-2100, Intel DH67BL,ADATA 4GB RAM, Seagate 320GB, Corsair CX430
Handset - Samsung Omnia W with Sony MDR-ED12
24-05-2010, 12:27 PM
How much did the case cost?
Since you're using an HDD with case, please do answer my previous question too. Whether it is safe to download directly into it using uTorrent (continuosly for 3-4 hours daily)? It won't heat up much?
25-05-2010, 09:10 AM
1. I would recommend using an internal HDD as an external drive using either an external case or docking station. External casing do come with a fan and you may like this one:
For details see the link below:
http://overclockershq.com/hardware-r...re-review.html
This is available in India @~ 1.7K Onwards. This is definitely a good choice because of the fan and the eSATA connectivity provided.
2. You can use it for n number of hours provided you dont keep the unit in some close space.
3. Fast Pendrive = Corsair
Fastest Pendrive = Corsair GT
Phenom II X4 940, Gigabyte MA790GP-UD4H, Corsair 6GB DDRII, AOC Fovi F22, Creative Gigaworks T3 Speakers, NZXT Phantom, Corsair GS600, 15 TB HDDs, Shure SRH440, Klipsch S4i, Ipod Touch 64gb
25-05-2010, 10:23 AM
New Gen Guru
The case was for Rs. 600-700..Made of aluminum and had a fan at back..
I used it for copying/backup data from one place to other...never used it continuously that much.
My friend used it as a store drive and used to connect it permanently...and access movies , document all the time..
Not much heating issue...with that much usage
Photography Gears -
25-05-2010, 09:46 PM
Thanks For the replies.
@static_x, the link didn't open (I'll try again tomorrow). However, I wanted a case because internal HDDs are cheaper, with this case I'll end up paying as much as a 500 GB Seagate 2.5 inch external HDD. So, I wanted to spend upto 600-700 on the case. But after enquiring today, it seems cases are not easily available here (in Kolkata), let alone a case with fan. So I might just plug it inside my cabinet.
26-05-2010, 09:52 AM
The link is working fine..check again...
26-05-2010, 11:29 AM
I am confused between Iomega & Seagate..
Suggest me..Which one is better ??
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
26-05-2010, 05:22 PM
yeah, the link is fine, it was a problem with my connection. That's y I wrote I'll try again tomorrow. But it's beyond my budget.
31-05-2010, 05:32 AM
Can anyone tell me the price of Cooler aster Xcraft 350 (305" case). I think it should be around 1200-1500 bucks. But what is this: http://www.ikonicit.co.za/index.php?...roduct_id=1897
Are they really giving it away for <400?! can this site be trusted?
---------- Post added at 05:32 AM ---------- Previous post was at 05:29 AM ----------
And just figured out, what's this: http://www.ikonicit.co.za/index.php?...product_id=156
A seagate 500 GB HDD for Rs. 510, what's wrong here?
