Old 16-05-2010, 11:07 PM   #1 (permalink)
Dust in the Wind
Skud's Avatar
Default Suggest a MFD
I am looking for an MFD with good scanner and occassional printing & copying uses. My budget is Rs 5000/-. Plz help.
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline
Old 17-05-2010, 11:59 PM   #2 (permalink)
Dust in the Wind
Skud's Avatar
Default Re: Suggest a MFD
No Answers???
Gaming Rig:
HTPC Rig:
Skud is offline
Old 18-05-2010, 05:43 AM   #3 (permalink)
Revolution's Avatar
I have bought HP Deskjet F2418 AIO @Rs.3800/- few days ago.
For occasional printing & copying uses u can consider it.
But not good for bulk printing.
Cartridges are expensive and not good for refilling.
Scanner is good.....
Revolution is offline
Old 18-05-2010, 08:44 AM   #4 (permalink)
Dust in the Wind
Skud's Avatar
Thanks. Actually I needed a scanner most with occassional printing. How's the cost of cartridges?
---------- Post added at 03:14 AM ---------- Previous post was at 03:11 AM ----------
Another question, what about Canon models? Are they better than HP?
Gaming Rig:
HTPC Rig:
Skud is offline
Old 18-05-2010, 09:49 AM   #5 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
Skud-I am zeroing in on Canon MP258 which comes at around 4K (here in Bangalore)...check that out at your nearest outlet...
I would request other members' feedback on this printer/device
Actually I am also looking for an MFD with same requirements as yours...plus I should also be able to print photographs shot from my digital camera...do suggest...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline
Old 18-05-2010, 11:37 PM   #6 (permalink)
Dust in the Wind
Skud's Avatar
Actually today I have bought the MP258 @ 3.4K. Scanning seems good; although the max resolution is 600 dpi, I think that's pretty reasonable. It comes bundled with a pack of three 4"x6" photo paper, so I can tell you about the printing results tomorrow.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 19-05-2010, 11:48 AM   #7 (permalink)
gagan007's Avatar
whoa....congrats man...I am eager to hear the results...I will also buy the device if you give green signal....
gagan007 is offline
Old 23-05-2010, 12:32 AM   #8 (permalink)
Dust in the Wind
Skud's Avatar
@ gagan007:-
Print quality is excellent IMO. Scanner is good as I have already told. Overall, I am highly satisfied with the purchase. Let me know what you have done.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 16-06-2010, 10:17 AM   #9 (permalink)
gagan007's Avatar
hey Skud...yesterday I finally purchased a MFD for home purpose. Although I went out with Canon MP 258 in mind, but it was not available at two outlets so went to Chroma. The salesman there persuaded me to buy HP F4488 instead...
It looks good. I haven't taken any photo prints yet...will post about it later...
Normal printing is at par with commonly found deskjets...It scans at upto 1200 dpi resolution.
gagan007 is offline
Suggest AMD config under rs.60,000 arshadmajeed PC Components / Configurations 11 08-05-2010 07:29 PM
Suggest which mobile to buy prasanna7287 Buying Advice 0 07-05-2010 03:06 PM
Suggest me best stock maintenance freeware prakashr85 Open Source 1 02-05-2010 01:35 AM
New MFD for heavy usage, Suggestions please Flashbang Hardware Q&A 0 25-04-2010 08:27 AM
suggest a phone, urgent Jaskanwar Singh Buying Advice 3 13-04-2010 04:11 PM
- by c4u
