Old 16-05-2010, 08:38 PM   #1 (permalink)
Default will games be fine on amd's x6 in future ??
Will future dx11 games be able to use all 6 six cores in amd's X6 proccessor ??
giprabu is offline   Reply With Quote
Old 16-05-2010, 09:34 PM   #2 (permalink)
Default Re: will games be fine on amd's x6 in future ??
you want an answer ?? seriously ? just figure it out....
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 16-05-2010, 09:51 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Games are all ready being written which realize 4 cores and HT. So 6 core logic should not be too far away. All the better for developers.
asingh is online now   Reply With Quote
Old 16-05-2010, 10:12 PM   #4 (permalink)
so if the games start recognising all 6 cores then amd's x6 will easily outbeat core i5-750 rite ??
and according to your verdict that future is not too far...
Old 16-05-2010, 10:26 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Again depends man. On the system. Not mutually exclusive.
Old 16-05-2010, 10:35 PM   #6 (permalink)
yup ..!
system with a 5850 card+x6 should be better than 5850+955BE ..rite ??
Old 16-05-2010, 10:41 PM   #7 (permalink)
you should be more focussed in the AMD Turbo Core. if it kicks well, i5's will have no place to hide, even in games. so do i7. Future directly proportional to popularity in X6 & i7 (the HT versions). more popular they become, more games will shift towards multi core setup.
Old 16-05-2010, 10:59 PM   #8 (permalink)
same questions were raised when there was a shift from high end duals to mid range quads..on games like GTA 4 we clearly saw Q6600s outperforming the E8400 and so on....i guess we can apply pretty much the same here......in the future more optimized games would run better on a 2.8GHz X6 than a 2.66GHz i5...even with the architectural advantage with the i5s.....there is not much difference between the i7s/i5s and P2s when it comes to gaming(at high setting at which we actually play at!), why the fuss?
Mobile Games --Multiplayer via bluetooth ?? Krazzy Warrior Mobiles and Tablets 2 22-08-2010 10:46 PM
GPU Computing for Games, High-fidelity Dynamics and Using GPUs via DirectX 11 tarun321 Programming 0 10-02-2010 08:52 AM
Need a GFX for the latest games... ╬Switch╬ Gamerz 3 22-01-2010 11:49 PM
Best Adventure Games... gsoul2soul Gamerz 33 08-04-2007 07:21 PM
Enjoy the best audio experience with Windows-based games ferrarif50 Tutorials 2 11-12-2005 09:55 AM
- by c4u
