16-05-2010, 02:47 PM
The Assassin
CPU for 40k
Hi ppl,
I'm planning to assemble a rig for 40k for gaming. I already have a 17" LCD monitor which I will be using and the config I've decided is as follows -
Processor : AMD Phenom ii X4 955 BE - 8k / 1050t 10.5k
Motherboard : Plz suggest a specific model thats overclocking friendly
RAM : 2*2 GB DDR3 - 5.8k
HDD : WD caviar blue 500GB - 2k
Graphics card : HD Radeon 5750 1 GB GDDR5 - 9k / 5770 - 10k
CD drive : 1.1k
Cabinet : NZXT Gamma : 2k
Total : 27900 - 31400
Ppl pls comment and suggest a mobo and PSU for this config as well as a UPS (UPS not in budget).
I ran across this calculator here but it only lists CM PSU options. Plz tell me how reliable are CM PSU's.
16-05-2010, 03:33 PM
Its Best only if its open
Re: CPU for 40k
Here hope this helps...
Gaming PC under 50k
16-05-2010, 04:24 PM
Wise Old Ghoul
Re: CPU for 40k
Originally Posted by Cybertonic
Hi ppl,
I'm planning to assemble a rig for 40k for gaming. I'll already have a 17" LCD monitor which I will be using and the config I've decided is as follows -
Motherboard : 785G based motherboard - 4.7k
HDD : WD caviar blue 500GB - 2.5k
Graphics card : HD Radeon 4870
CD drive : 1.1k
Cabinet : Zebronics Antibiotic : 2.2k
Wifi card - not sure of price
Ppl pls comment and suggest a PSU for this config as well as a UPS (UPS not in budget).
Processor : AMD Phenom ii X4 955 BE - 8k CHANGE IT TO EITHER 965 OR NEW 1050T
Motherboard : 785G based motherboard - 4.7k SEEMS OK BUT U CAN GO FOR 880G BASED MOBO AT THE SAME PRICE
RAM : 2*2 GB DDR3 - 5.8k OK
HDD : WD caviar blue 500GB - 2.5k SEEMS DECENT
Graphics card : HD Radeon 4870 NOW THIS IS THE AREA OF CONCERN
SEE 4870 IS A POWERFUL CARD BUT ITS POWER HUNGRY TOO
BETTER GO FOR HD 5770 ALMOST SAME/BETTER PERFORMANCE WITH LOW POWER USAGE
CD drive : 1.1k
Cabinet : Zebronics Antibiotic : 2.2k BETTER OPTION IS NZXT GAMMA AT 2K
16-05-2010, 04:37 PM
Re: CPU for 40k
i suggest going for last option. multitasking + gaming, all in 1.
other than ECS none selling 880G cheap. a 785G board @ 2.1k, Biostar TA785G3 HD seems good fit.
price have dropped i feel. 5.3k or so good one.
should get for 2.1k
yup. true.
have u checked out the new Cooler Master USP 100? cost 3.2k. feature wise, not much. but look wise, it rocks.
16-05-2010, 04:39 PM
Wise Old Ghoul
Re: CPU for 40k
^^WHOA!!!!!!
looking evil
will suit me....
16-05-2010, 04:50 PM
Re: CPU for 40k
check this buying guide..
errr that cabinet above is a nono for me
16-05-2010, 04:56 PM
Wise Old Ghoul
Re: CPU for 40k
Originally Posted by rajan1311
urs was good too
but ur mobo recommendation was not uptu the mark,its too low featured
may be bcoz of its low features at that price
looks good though
16-05-2010, 04:59 PM
Re: CPU for 40k
^^WHOA!!!!!!
looking evil
will suit me....
yes, look evil. not too much. perfectly suites for those who wants some style with a few good features. not much talk about. cable management is poor. only 1 X 120mm LED red/blue (depending on the colour of cabby). 90degree HDD placement. bottom PSU placement. 5 fan capacity. its like a Cooler master + NZXT hybrid.
 link nehi khulta.
yaya for me
16-05-2010, 05:02 PM
Wise Old Ghoul
Re: CPU for 40k
and price is a bit too high with those specifications
 link nehi khulta.
khul to raha he
its from TechForumIndia
yaya for me
pehle result to aaney de
16-05-2010, 05:06 PM
The Assassin
Re: CPU for 40k
I've head that biostar mobos arn't that good. I'd prefer Asus Gigabyte or MSI
---------- Post added at 05:06 PM ---------- Previous post was at 05:02 PM ----------
Ppl ty for sooo many replies  but plz tell wether CM PSUs r good or not and also tell abt a good mobo(i can't find 880G based ones on any online store).
16-05-2010, 05:12 PM
Wise Old Ghoul
Re: CPU for 40k
its not that biostar mobos are bad
its the model which make it bad or good due to the features on it
if u still think like that,then opt for MSI /gigabyte(but they'll be a lil costly)
also CM PSUs arent bad
its the Model which......bla bla bla.......
CM extreme series should be neglected
corsair/antec/FSP/Seasonic are the nice and reputed brands to look for
and where do you stay?are u going to buy ur PC online?
16-05-2010, 05:16 PM
The Assassin
Re: CPU for 40k
nop i'm going to buy them frm nehru place in delhi but i'll go there only when config is decided as its a bit far frm my home
16-05-2010, 05:17 PM
Re: CPU for 40k
well yes. upto 2.5k, it'll be sweet deal. at 3.2k + tax, no more sweet. still, if looks matter, can be tried. still i'll say price is high.
khul to raha he
nehi kulta yaar. tried from PC. wel will try using Opera (desktop as well as mini)
yaar don't remind me about results
were. no more. they are good if u go for the T series. however Asus quality coming down the pipe. Gigabyte price going uppppp..... & no sigh of stopping. MSI is value. priced right.
except extreme power & the + version. everything good.
than go for 785G or 790GX (MSI 785GM E53. the bio* i mentioned above) both are good mobo & priced well too.
16-05-2010, 05:19 PM
BLUE IS THE COLOUR
Re: CPU for 40k
Hm..Now I think so.I have Biostar TA785G3 HD.Features and price are good.
But lacking perfection.PC takes so much time to wake up from sleep.Also USB device cant wake up PC from S3 sleep.I have tried my best in bios, even updated it.Still no solution  .Like this small inconveniences are there.But in MSI all were perfect.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
16-05-2010, 05:28 PM
Re: CPU for 40k
But lacking perfection.PC takes so much time to wake up from sleep. Also USB device cant wake up PC from S3 sleep.I have tried my best in bios, even updated it.Still no solution  .Like this small inconveniences are there.But in MSI all were perfect.
this has been 1 issue, thats been plaguing not only biostar but many other brands too.
16-05-2010, 05:31 PM
The Assassin
Re: CPU for 40k
ppl the calc said around 560W so what should i go for?
16-05-2010, 05:32 PM
Wise Old Ghoul
Re: CPU for 40k
its got just 1 and that too for 6k
what r u talking about???
#19 (permalink)
BLUE IS THE COLOUR
Re: CPU for 40k
@OP
Ist
Go for
phenom II X4 955 BE @ 8k
MSI 785GM E53 @ 5.4k
Corsair vx 450W @ 3.6k
IInd
Go for
Phenom II X6 1055 @ 9.5k
MSI 890GX G65 @ 7.5k
Corsair vx 550W @ 4.5k
Graphic card-your selection.
16-05-2010, 05:36 PM
#20 (permalink)
The Assassin
Re: CPU for 40k
---------- Post added at 05:33 PM ---------- Previous post was at 05:32 PM ----------
read the first post -.-
---------- Post added at 05:36 PM ---------- Previous post was at 05:33 PM ----------
@OP
Ist
Go for
E51 is available for 1k less
#21 (permalink)
Wise Old Ghoul
Re: CPU for 40k
i still dunno wot u saying?
what did u bought for 6k?
16-05-2010, 05:42 PM
#22 (permalink)
Re: CPU for 40k
go for Corsair VX450W, if going for HD5770. anything above, VX550W will suffice. if going by CM PSU, go for GZ 550W, it falls between Corsair VX450W & 550W.
its a calculator made by CM to calculate what wattage PSU to be used by a particular system. nice 1. tried a few time before. however the HD5670 option was missing earlier. hope they fixed it now.
@OP
Ist
Go for
IInd
Go for
a combo will work too:
MSI 785GM E53 @ 5.3k
Sapphire HD5770 1Gb @ 9.5k
told u, it'll be costly. may try the Gigabyte 785G with USB 3.0 for 5.8k or so.
16-05-2010, 05:43 PM
#23 (permalink)
BLUE IS THE COLOUR
Re: CPU for 40k
E51 is mATX.If u fit a monster card in it,you'll lose your both PCI's.But E53 is ATX and there is enough space to breath.
16-05-2010, 05:45 PM
#24 (permalink)
Wise Old Ghoul
Re: CPU for 40k
its a calculator made by CM to calculate what wattage PSu to be used by a particular system. nice 1. tried a few time before. however the HD5670 option was missing earlier. hope they mixed it now.
that i know
i was just confused about what he bought?
and yes they have included 5670
i prefer this one
http://thermaltake.outervision.com/index.jsp
16-05-2010, 05:55 PM
#25 (permalink)
Re: CPU for 40k
also the quality of E53 good. 140W proccy support (not matters much as X6 limited to 125W so is X4 965 BE).
---------- Post added at 05:55 PM ---------- Previous post was at 05:49 PM ----------
that i know
he not brought anything yet. just telling price of the MSI 880G. its a bit too costly. at 6k.
you know, something wrong. now this link too not opening in Chrome. let me try in opera. GPRS sucks. sucks so bad.
NOTE: opera told its error.
16-05-2010, 05:57 PM
#26 (permalink)
The Assassin
Re: CPU for 40k
the CM 1 and this 1 give the same result
and theres 1 more
http://www.extreme.outervision.com/p...ulatorlite.jsp
btw ppl this is the final config -
Processor : 1050t 10.5k
Motherboard : MSI 785GM E53 - 5.4k
CD drive : 1.1k
Cabinet : NZXT Gamma - 2k
PSU : CM GX 500w - 4.3k
Total : 40.1k
plz comment
16-05-2010, 05:58 PM
#27 (permalink)
Wise Old Ghoul
Re: CPU for 40k
i can calculate it for ya if u want
just post the rig
16-05-2010, 06:04 PM
#28 (permalink)
Re: CPU for 40k
and theres 1 more
CD drive : 1.1k
Total : 40.1k
plz comment
that card available for 9k, if u choose Biostar only. however i don't think SMC sells bio card. but card was a good one. got a good aftermarket cooler. rest everything good. if settling for sapphire/MSI HD5770, i'll suggest opt for the MSI HAWX edition.
just post the rig
yah, no problem bro. calculated it earlier once. and its coming good. will setup the connection once more. than try again.
16-05-2010, 06:07 PM
#29 (permalink)
Wise Old Ghoul
Re: CPU for 40k
its 5750 but at 8k not 9k
---------- Post added at 06:07 PM ---------- Previous post was at 06:06 PM ----------
nice rig anyways
---------- Post added at 06:07 PM ---------- Previous post was at 06:07 PM ----------
MSI 5770 1gb available at 9.1k at SMC
16-05-2010, 06:15 PM
#30 (permalink)
Re: CPU for 40k
nice rig anyways
oh yes. damn. my eyesight failing day by day. at 9.1k, the MSI HD5770 a nice buy. considering MSI's product are generally better than BIO*. however i don't understand why most shops, online & street level don't keep 512Mb variants. 512Mb version of HD5670 missing in SMC also.
---------- Post added at 06:15 PM ---------- Previous post was at 06:12 PM ----------
piyush, both PSU calculator links opening now. i know something wrong with the net settings.
