Old 15-05-2010, 12:33 PM   #1 (permalink)
Question extending router range...help!
i have the basic modem/router provided by BSNL
Its a Nokia Siemens Networks Resedential Router 1600
i have a laptop and a ipod touch and was wondering if there is any way to extend the range of my modem without wasting any money.Based on my experience the router is not very good and i cant get proper reception in my ipod touch everywhere in my house
btw the router n computer are on the 1rst floor of my house if that helps
rhk217 is offline
Old 15-05-2010, 01:37 PM   #2 (permalink)
stoned mario
arshadmajeed's Avatar
Default Re: extending router range...help!
if you are interested to DIY,
this is very useful
http://digiblast.blogspot.com/2008/0...uide-wifi.html
very easy
and cost under 350INR
arshadmajeed is offline
Old 15-05-2010, 02:29 PM   #3 (permalink)
You can use alternative firmware to increase the transmission power of your router and ensure a long range.
Ps : If you download an inappropriate firmware version or make a mistake during the installation, the router may quickly and irreparably be damaged.
Go to the website: www.dd-wrt.com and click on the router database and look for your model and download the firmware file with extension ".bin". Before installation the new firmware detach all lan cables from the router except for the lan cable of the pc that has the firmware file that you have just downloaded.
Do a hard reset, now flash the firmware by typing 192.168.1.1 or certain routers have different default ip address, go to the firmware section and upgrade the firmware.
Lastly before you start the dd-wrt configuration, you will need to hard reset the router again.
Once restarted, you will see the firmware page..increase the specified value in the "TX power" field under the wireless/advance settings from around 71mW to a higher value in small steps. Upto 100mW is allowed by default, even though u can boost it to more than 200mW with further tweaking, but be careful; increasing this value will force your router's components to run at higher powers thus producing more heat.
As you have upgraded the router firmware, you have opended up a treasure chest of settings with new features etc.
Hope this helps. I read this guide @ chip this month issue..
neerajvohra is offline
Old 15-05-2010, 03:10 PM   #4 (permalink)
You could also try changing the Wi-Fi Channel, in order to remove interference
Aspire is offline
Old 15-05-2010, 08:19 PM   #5 (permalink)
@neeraj : ya i read chip too ....but i wasnt sure if it could be done on this stupid bsnl modem....as the router may get damaged in de process....so i was just cheking if somebody had done it or found a risk free way to do it in this modem
@aspire: im a wifi noob...dint understand anything u said ..plz explain
rhk217 is offline
Old 15-05-2010, 10:28 PM   #6 (permalink)
@rhk217 lol two chip readers are here @digit forum...lol neway you can certainly give it a try..but before trying do check if your "stupid bsnl router" is in the list
PS : if you have the recovery disc of your router..then recovering to old firmware wont be a problem
Old 16-05-2010, 08:41 AM   #7 (permalink)
i dont hve a recovery risk and i dont even kno the model nam of this modem....it says nokia siemens residential router 1600 ...certainly nothin lik dat in the router database of www.dd-wrt.com ...guess im stuk wid dis
rhk217 is offline
Old 16-05-2010, 10:46 AM   #8 (permalink)
stoned mario
dood juz make the extending antenna
Old 16-05-2010, 01:19 PM   #9 (permalink)
ya ...thats the only option i guess ...ill get to it as soon as i get time nd the things...btw hve u tried it??
rhk217 is offline
Old 16-05-2010, 02:22 PM   #10 (permalink)
stoned mario
actually had it made by a frnd f mine who does electric stuff to connect 2 neighboring houses
Old 19-05-2010, 01:54 PM   #11 (permalink)
how is it??
rhk217 is offline
Old 19-05-2010, 02:03 PM   #12 (permalink)
stoned mario
works fine ,....though a bit of off n on condition in rain
AMD x6 1055T/Msi GXM g-65/6gb corsair dominator 1600MHz\Saphire Radeon 5850HD/benq G2220/Cooler Master GX 650W\cooler master N-520/WD green 1tb\NZXT m59
Old 19-05-2010, 09:16 PM   #13 (permalink)
stoned mario
http://www.tested.com/news/how-to-us...i-network/298/
juz stumbled on this thot f tellin u,didnt read full
Sporadic "Cable disconnected" issues - MTNL wireless router shaunak Hardware Q&A 2 23-06-2010 02:40 PM
Belkin N+ router vs Belkin N+ Blackfire Hardware Q&A 0 21-01-2010 06:53 PM
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
VIA UniChrome Pro Display Driver ver 0.8 gary4gar Open Source 19 22-12-2007 02:09 PM
All About Unicode /programming with Unicode rohan Tutorials 6 09-11-2007 11:03 AM
- by c4u
