14-05-2010, 07:49 PM
Upgrading PC
I need to upgrade my home PC.
I can use the cabinet,cd/dvd drive,mouse,keyboard and UPS.
Rest all i need to purchase.
My budget is 25000.
Please suggest me the best configuration,which i can get in this much price.
I am mainly looking for a gaming configuration....Please help.
14-05-2010, 08:12 PM
Re: Upgrading PC
can try out these:
Processor: Athlon II X4 630: 4.7k
Motherboard: Biostar TA785G3 HD: 4.1k
Ram: A-Data 2Gb DDR3 1333Mhz: 2.7k
Hard Disk: Western Digital 500Gb Blue: 2k
Graphics Card: Sapphire HD5670 512Mb: 5.3k
PSU: FSP Saga II 400W: 2.1k
Cabinet: use old cabby but i suggest buy new one. anyone you like.
Monitor: Benq G2020HD 20”: 6.8k
Total: 27.7k. to lower more, go for X3 435 & save 1k. lower grade board, Biostar TA785G A3+, saving 0.5k. however don't compromise on PSU. also as you mentioned gaming, going for anything below the card i given is not recommended.
14-05-2010, 08:39 PM
Simply a DIGITian
Re: Upgrading PC
I wud say don't compromise on proccy and mobo. Go as sam suggested you.
If you're really out of budget then compromise on gfx crd rather than proccy or mobo
And sam......gr8 config as usual
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
14-05-2010, 08:51 PM
Wise Old Ghoul
Re: Upgrading PC
@all
he dont have to change mobo or gfx card
he shud change his monitor
Dell 19" IN 1910N is the good choice at 5750
and yes he can go for x3 435
14-05-2010, 09:03 PM
Re: Upgrading PC
yah thanks yaar. nowadays u less active here. busy in studies?
Originally Posted by piyush120290
@all
WOW. where u found that monitor? cost wise it beats all.
14-05-2010, 09:08 PM
Wise Old Ghoul
Re: Upgrading PC
^^SMC
but the max resolution it supports is 1368X768
14-05-2010, 09:35 PM
throttle press fire !!
Re: Upgrading PC
Piyush, bro..i just LOVE your signature statement regarding argueing with idiots..lol ... where did u find that is what i wud ask..hehe..
Intel Core i7 930;GA X58A-UD3R;Corsair 3x2GB 1600MHz
HD5850 1GB GDDR5;cabinet-Asus Vento 3600;DELL SP2309W
Razer Arctosa;Razer Death Adder;
Altec lansing 2.1 MX5021;Asus Xonar DX for MX5021
15-05-2010, 03:41 PM
Wise Old Ghoul
Re: Upgrading PC
i read it on a calender
15-05-2010, 04:20 PM
Re: Upgrading PC
please go through this buying guide
15-05-2010, 06:35 PM
laborare est orare
Re: Upgrading PC
For monitor, go for the AOC 19" monitor. It is having 5000:1 dynamic contrast ratio and 1440X900 max resolution, which is actually good for gaming. Price in Kolkata is 5.5k. Go for this. Resolution 1366X768 is actually the max res of a 18.5" monitor. For better result opt for the AOC one.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
15-05-2010, 08:27 PM
Re: Upgrading PC
One should never compromise on gfx card if the machine is for gaming, Proccy doesn't affect gaming as much as gfx card. I'll again stress like in another thread, go for the best gfx card in your budget look for the proccy later.
15-05-2010, 08:45 PM
Re: Upgrading PC
so which graphics card do you recommend ?
16-05-2010, 07:07 AM
Re: Upgrading PC
Actually, I have not looked into graphics cards of that price range recently, But I would suggest going for a DX 11 card as that would be somewhat future proof. I would recommend Radeon HD 5750. but again, I don't know the exact market price, somewhere around 8000. Just see if it fits (in your budget)
