Old 14-05-2010, 07:23 PM   #1 (permalink)
Exclamation i7 920 running at 2.79GHz continiously
guys my i7 920 is constantly running at 2.79GHz from 5th day of purchase even if no process is running and CPU utilization is 1%
is this some thing to do with windows or what
WHY?????????????
This the cpu-z Validator output
Intel Core i7 920
Windows 7 Ultimate Edition (Build 7600)
CPU Arch : 1 CPU - 4 Cores - 8 Threads
CPU PSN : Intel Core i7 CPU 920 @ 2.67GHz
CPU EXT : MMX, SSE (1, 2, 3, 3S, 4.1, 4.2), EM64T, VT-x
CPUID : 6.A.5 / Extended : 6.1A
CPU Cache : L1 : 4 x 32 / 4 x 32 KB - L2 : 4 x 256 KB
CPU Cache : L3 : 8192 KB
Core : Bloomfield (45 nm) / Stepping : D0
<red>Freq : 2800.16 MHz (133.34 * 21)</red>
MB Brand : Intel
MB Model : WX58BP
NB : Intel X58 rev 12
SB : Intel 82801JR (ICH10R) rev 00
GPU Type : Radeon HD 5670
GPU Clocks : Core 157 MHz / RAM 300 MHz
DirectX Version : 11.0
RAM : 4096 MB DDR3 Dual Channel
RAM Speed : 533.4 MHz (2:8) @ 7-7-7-19
Slot 1 : 2048MB (10700)
Slot 1 Manufacturer : Kingston
Slot 2 : 2048MB (10700)
Slot 2 Manufacturer : Kingston
Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Intel WX58BP Server Board
ATI Radeon HD 5670 1GB GDDR5
Kingston 2 X 2 GB PC3-10600 DDR3 RAM 1333 MHz
Cooler Master Silent Pro 600W
Cooler Master 690
cooldude is offline
Old 14-05-2010, 07:52 PM   #2 (permalink)
Default Re: i7 920 running at 2.79GHz continiously
Ill say something very obvious....check if speed step is enabled in the BIOS...btw, why 4GB memory ?
rajan1311 is offline
Old 15-05-2010, 07:15 AM   #3 (permalink)
there iss nothng running on the machine
Cooler Master 690
cooldude is offline
Old 15-05-2010, 09:28 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Download LinX and stress it. The speeds should go up.
asingh is online now
Old 18-05-2010, 05:09 PM   #5 (permalink)
I did the stress testing using linX the speed goes up from 2.79GHz to2.8
the cou utilization goes 100% memory utilization is 95%
But it does not return to 2.7Gz stock speed!!
Cooler Master 690
cooldude is offline
Old 18-05-2010, 05:28 PM   #6 (permalink)
Super Moderator
asingh's Avatar
That screen shot clearly shows you cores are not on load. What is the issue now..? Or I did not understand..?
Old 18-05-2010, 10:38 PM   #7 (permalink)
the speeds should step down at idle (speedstep?) and even at load it should run at 2.66GHz.
Win hardware worth 11k!!
Old 19-05-2010, 12:16 AM   #8 (permalink)
rk
cooldude what is the wallpaper you are using
can u share its url.
rk is offline
Old 19-05-2010, 11:20 AM   #9 (permalink)
cosmos's Avatar
Dude,
From the screenshot i can tell that you must immediately uninstall the 2nd widget completely. The intel i7 turbo booster. I had the same installed when i got my new pc and found that it increases the processor speed whenever necessary. But the disadvantage of that it is not very efficient and heats up the CPU; also this widget consumes CPU power when it starts working.
So uninstall the widget completely, and go to msconfig and disable it from startup as well if it still resides there.
Hope that helps. Try the steps mentioned above and report back.
Cheers,
Cosmos
P.S. Why only 4gb ram!!! U r not utilizing the tri-channel power of i7 dude.
cosmos is offline
Old 19-05-2010, 06:16 PM   #10 (permalink)
Talking Re: i7 920 running at 2.79GHz continiously
@Cosmos: I Uninstalled the widget completely disabled it from my startup but cpu-Z still shows
core speed 2800MHz
Could u explain it??
i bought Only 4GB becoz my budget way exceeded way abv the limit
Actualy it was 45k w/o monitor
but i bought 55k w/o monitor
Cooler Master 690
cooldude is offline
Old 19-05-2010, 09:02 PM   #11 (permalink)
One of the features on the 920 is triple channel memory. To tell in a very crude way, you need RAM in multiples of 3, infact the sticks should be in multiple of 3. So its 3GB (1x3) or 6GB(2x3) or 12GB(2x6) and so on...
not a big difference between dual and tri channel in practical apps anyways...
Old 19-05-2010, 11:57 PM   #12 (permalink)
Super Moderator
asingh's Avatar
The MCH sees the three DIMMs as one large module, and the data channeling is quicker. Throughput between the CPU and RAM goes up.
Old 20-05-2010, 08:56 AM   #13 (permalink)
but how much does it make a difference, in real life? not synthetics..
Old 20-05-2010, 10:32 AM   #14 (permalink)
Super Moderator
asingh's Avatar
Not much. Here is an article.
Old 20-05-2010, 10:47 PM   #15 (permalink)
Guys Back to the topic Yaar it is still at 2800Mhz in cpuZ
Cooler Master 690
cooldude is offline
Old 21-05-2010, 09:51 AM   #16 (permalink)
Super Moderator
asingh's Avatar
OP:
Do these three things. And lets end this.
1. Download LinX.
2. Post a screen shot of the first CPU-Z tab with LinX running in the background.
3. Post a screen shot of the first CPU-Z tab with LinX NOT running in the background. The system should be on idle.
Old 21-05-2010, 08:04 PM   #17 (permalink)
These r the screen shots u requested
Cooler Master 690
cooldude is offline
Old 22-05-2010, 01:17 AM   #18 (permalink)
Super Moderator
asingh's Avatar
Try to reset the BIOS once from the BIOS setting.
Sam/Azad/Rahul:
Could you guys please tell him your system setting from the BIOS, specially the automatic settings.
Old 22-05-2010, 10:35 PM   #19 (permalink)
will post tomorrow morning. however mine is a now ancient P4. any use?
Sam is online now
Old 23-05-2010, 12:18 PM   #20 (permalink)
Super Moderator
asingh's Avatar
Sam Gamer I guess has an i7..!
Need help in running 32-bit games in 64-bit OS Sid_gamer Gamerz 3 26-04-2010 12:06 PM
GTX280 not running with AsRock motherboard! prankie Hardware Q&A 18 16-04-2010 09:42 PM
PC is running but there is no display Techn0crat Hardware Q&A 1 25-03-2010 09:46 PM
Any one running gentoo? parimm Open Source 3 15-03-2010 12:27 AM
XFCE not working...!!! vipul Open Source 2 19-05-2005 12:41 AM
- by c4u
