Old 14-05-2010, 09:55 AM   #1 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Is there any method to watch DTH in TV and PC ?
Now I am using local cable connection and watching in both TV and PC.I have Tuner card - pixelview play TV pro3.But now ESPN and others are not getting in cable so i decided to shift to DTH.But I need to watch that in TV and PC.(My mom is a serial addict).So I cant watch sports in TV.(PC is in upstairs).I need to record TV programs also.Suggest me a best DTH service and method to watch in both TV and PC.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 14-05-2010, 10:57 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Is there any method to watch DTH in TV and PC ?
u can watch on both Tv and PC but... same channel
because the control will be in STB (set top box).
u need to have 2 connections..
if u consider any DTH service this is the same problem..
i am using big tv.. they have a good offer for this type.. if u want to get 2 connections for same house. then for second connection u need to pay only half of the first! connection. that is if u have connection where u will pay monthly 250. then the second connection will cost only 125 monthly..
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 15-05-2010, 08:57 AM   #3 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Please anyone help me to find a solution for this.
ajai5777 is offline
Old 15-05-2010, 10:49 AM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
Visit this : http://askvarad.blogspot.com/2009/06...htv-to-pc.html
VarDOS is offline
Old 15-05-2010, 12:56 PM   #5 (permalink)
AJJU
azzu's Avatar
same same problem here to..
i got my Pc on upstairs to.. Plz help out guys...
Btw : varad ur site shows how to connect Dth to pc but not what our main problem is
plz better read the total Post
I love and Live to Design
azzu is offline
Best soft to watch tv in PC temperworld QnA (read only) 5 12-02-2008 04:30 PM
Apple TV nepcker QnA (read only) 33 30-03-2007 12:49 PM
Apple TV just plain works nepcker Technology News 7 25-03-2007 11:27 PM
Connect TV to Pc blademast3r Tutorials 17 23-10-2006 04:59 PM
How to make your PC quiet sara2002 QnA (read only) 6 17-10-2004 04:05 PM
- by c4u
