13-05-2010, 10:22 PM
vx450 & apc
I'm planning on getting a new pc in a couple of days. I've decided on everything except the psu and ups. The more I read about PFC and stuff the more confused I get. Some say their vx450 works with apc (the simlated sine thing) and others say it doesn't and can even be harmful to the system.
Can someone clear up this for me? Would the vx450 work with a APC BR550CI-IN 550VA ups? Also if it doesn't can you recommend a psu and ups combination that work well together? something I can get for around 6.5k?
Thanks
13-05-2010, 11:01 PM
Super Moderator
Re: vx450 & apc
Get a 650 APC. UPS are calibrated to output/support a load of ~65%.
550 rated = 358W support
650 rated = 422W support
13-05-2010, 11:12 PM
Re: vx450 & apc
Hmm, so would a APC BACK-UPS 650VA work fine with a vx450 without any problems or putting my system in danger?
14-05-2010, 05:58 AM
Re: vx450 & apc
What is the difference between APC Back and APC Smart series UPSs ?
Why Smart series so costly ?
14-05-2010, 10:06 AM
Super Moderator
Re: vx450 & apc
I am using a 1.1KVA APC with my TX650. Been fine. Almost 365 days...!
14-05-2010, 10:09 AM
Re: vx450 & apc
I am using a Microtek Heritage 600VA and a VIP GOLD 500W. If i upgrade to a VX 450 will my current UPS support it ?
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
14-05-2010, 12:11 PM
Re: vx450 & apc
thanks a lot asigh.. going with vx450 and apc 650va
14-05-2010, 12:48 PM
Super Moderator
Re: vx450 & apc
600VA = ~ 390W of support.
If you pull greater than this via the PSU, it will not support it. It is not about which PSU you are using, it is about how much your system will draw at load, and is of course within the PSU calibrated limit.
14-05-2010, 12:57 PM
Wise Old Ghoul
Re: vx450 & apc
awww man..
i never knew this stuff
it means i have to replace my ups too bcoz i'll be upgrading my rig this june
14-05-2010, 02:06 PM
Re: vx450 & apc
Actually i have two 600VA UPS . 1 UPS is powering the CPU alone and the other one is powering the monitor and the modem, does it make any difference ?
14-05-2010, 02:11 PM
BE FREE
Re: vx450 & apc
not much you would be saving 50-100w load from first ups depending on what type of monitor you have.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
14-05-2010, 02:17 PM
Re: vx450 & apc
Asigh, could you explain the calculation 600VA ~ 390W ?
14-05-2010, 02:42 PM
Super Moderator
Re: vx450 & apc
As a rule of thumb, the efficiency of UPSs' is 65%. So 390W is 65% of 600. Rest of the 'energy' is wasted in heat.
14-05-2010, 02:45 PM
Re: vx450 & apc
Ok, If I add a HD 5770 to my current config, what would the total power drawn from a VX 450 ?
14-05-2010, 04:02 PM
Super Moderator
Re: vx450 & apc
14-05-2010, 07:21 PM
Re: vx450 & apc
Well, not exactly correct terminology, but correct nevertheless .
650VA is the output,but not in watts,but in VA. Output in VA x Power factor = Output in Watts.
For APC UPS, use power factor as 0.6 (according to apc docs).
I have been using a 500VA APC UPS for almost 2 years now,with a VX550. Your system would never use more than 200-250W.
If you get higher VA UPSes, you get a higher peak output and longer battery life, example: if your system somehow draws 300W, the UPS will give an overload warning and switch off in case of a 500VA UPS, even if the mains are alive (no power cut).
14-05-2010, 08:55 PM
Super Moderator
Re: vx450 & apc
Is it not pretty dumb to have a 550W PSU backed by a 500VA UPS..? The day you hit that load your system blacks out, or the UPS starts to whine like crazy..? OP suggested he has a 450W PSU, so I suggested the UPS accordingly -- how would we know how much he will actually pull.
Could you upload the white paper/link which you referred too. Seems interesting.
14-05-2010, 09:11 PM
Wise Old Ghoul
Re: vx450 & apc
@asigh
u mean the ups rating should around 1.5 times the rating of a PSU?
(just focusing on numbers)
14-05-2010, 09:15 PM
#19 (permalink)
Re: vx450 & apc
... OP suggested he has a 450W PSU, so I suggested the UPS accordingly -- how would we know how much he will actually pull.
Well I think I might as well run this by you guys before I get it. Here's the config.
core i5-750
Gigabyte GA-P55M-UD2
2gb ddr3 kingston (1 more 2gb ddr3 in a couple of months)
palit 9800GT sonic 512MB
2 hdd's - 160gb sata, 80gb IDE
17" monitor - res 1280x1024
The vx450 would be enough right?
Reason: Forgot the hdd's
14-05-2010, 10:33 PM
#20 (permalink)
Re: vx450 & apc
Um...well when i got my UPS i had a low end PC,so 500VA was fine, but after all the "moderate" upgrading, the 500VA still serves the purpose, i get a few minutes to shut down my PC, which is fine.
I have never loaded my PC up so much so that i get the overload warning, i have even connected my monitor to the UPS.
anyways, here is the doc, rep (do they have it here?) me for it
http://www.ptsdcs.com/whitepapers/14.pdf
15-05-2010, 08:07 AM
#21 (permalink)
Re: vx450 & apc
Hhm, if its giving 5 mins backup then i will go for VX 550 and i will be using it on 600VA UPS. UPS will run only the CPU. Monitor is connected to a separate UPS
15-05-2010, 09:18 AM
#22 (permalink)
Re: vx450 & apc
^yes that would be ideal, i was just sharing my experience to show that it works, but not very well (good enough for me, but not others).
15-05-2010, 09:28 AM
#23 (permalink)
Super Moderator
Re: vx450 & apc
Originally Posted by piyush120290
@asigh
Just remember UPS have 60-65% efficiency. Calculate it from there.
15-05-2010, 03:29 PM
#24 (permalink)
Wise Old Ghoul
Re: vx450 & apc
I have few questions regarding Thermaltake Power Supply Calculator
1-system type:is that should be single socket for me even if i have quad core cpu?
2-CPU utilization at which time? Should i consider it when at load?
3-In RAM section , by sticks does he mean the available slots in mobo or the installed chips on it?
4-Capacitor aging????
15-05-2010, 04:19 PM
#25 (permalink)
Re: vx450 & apc
1)Yes urs is a single socket mobo, servers have multi socket motherboards (up to 4 ?)
2)Load at worst case - peak
3)The sticks you have installed
4)just put the recommend value...
This is a very rough calculation of the PSU wattage required and not the actual power consumption of the PC.
15-05-2010, 07:29 PM
#26 (permalink)
Wise Old Ghoul
Re: vx450 & apc
thanks anyways
though the last query is still a pain for me
