Old 13-05-2010, 09:41 PM   #1 (permalink)
ninad_mhatre85's Avatar
Default PC upgrade
Hi
i want to change the processor , mobo & ram of my machine .. there are 2 reasons for it ..
1 ) i use adobe lighthouse which hangs if i select more than 30 photos ... which irritates me
2 ) i am using same hardware for 2 yrs and i guess i need upgrade
my budget is 15K
i need at least 2GB ram suggest me which brand to buy ?
Life is not measured by moments u breath but by the moments that take ur breath away
ninad_mhatre85 is offline
Old 13-05-2010, 10:17 PM   #2 (permalink)
bORn To RIse....
rahul.007's Avatar
Default Re: PC upgrade
you haven't mentioned config of your old rig.... please mention it first then only we can suggest possible upgrades....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 14-05-2010, 12:10 AM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
As you haven't mentioned your previous configuration so it is hard to suggest sumthing. Coz we need to know the cabinet, and PSU most to suggest something. Other components like Monitor is also necessary somewhere.
BTW with some assumption I suggest this upgrade:
AMD Phenom II X2 555BE + MSI 785G-E53 @ 10.5k
Transcend/Kingston 4GB(2x2GB) DDR3 1333MHz @ 5k
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 14-05-2010, 12:21 AM   #4 (permalink)
he into photo-shopping. so a quad core will be best for him. he can go for the X4 635. or 630. if there is a price cut (as X4 640 been released), he should get X4 635 for below 5k. also 4Gb ram will be needed.
Sam is online now
Old 14-05-2010, 12:00 PM   #5 (permalink)
old config :
AMD Athlon X2 64 bit ( 2.1 GHz )
Asus Mobo
1 GB ram
circle cabi & PSU ( i am not sure about PSU wattage )
Old 14-05-2010, 12:05 PM   #6 (permalink)
Wise Old Ghoul
Piyush's Avatar
Originally Posted by ninad_mhatre85 View Post
old config :
Asus Mobo
1 GB ram
CIRCLE name is enough to predict the future
well u shud go for
AMD Athlon II x4 630 @4.5k or less
2*2gb kingston RAM (1333MHZ) @ 5.5k
MSI or GIGABYTE or BIOSTAR mobo based of 785/880 chipset @5k appx
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 14-05-2010, 12:17 PM   #7 (permalink)
yes, its like "Circle, naam hi kafi hain". use it once & you'll never forget (forgive) us
Sam is online now
Old 14-05-2010, 12:19 PM   #8 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^lol
hey what about the rig?
is it ok?may be the prices should differ a bit
--Get Backers
Piyush is offline
Old 14-05-2010, 12:38 PM   #9 (permalink)
^^lol
rig is good. MSI mobo available for 5k & below. but gigabyte? which 1? i not yet seen a 785G/880G based giggy below 5.5k. no online shop or any store. only gigabyte is a 740G based for 2.5k or so. DDR3.
Sam is online now
Old 14-05-2010, 12:44 PM   #10 (permalink)
Wise Old Ghoul
Piyush's Avatar
i knew smthng was not ok here
i dunno y giga r so costly,just like asus?
--Get Backers
Piyush is offline
Old 14-05-2010, 01:15 PM   #11 (permalink)
Simply a DIGITian
Ya go for Biostar boards. It'll come within your budget. May be Biostar TA785GE @ 3.8k
Or if you can slighly strech your budget g for Gigabyte ones like MA785G-U2SH, MA785G-UD2H @ 6k or so.
Old 17-05-2010, 08:18 PM   #12 (permalink)
i was out of town .. so could not the forum, will have to check for prices here in mumbai
Thanks for your suggestions
Old 17-05-2010, 09:59 PM   #13 (permalink)
The Assassin
Cybertonic's Avatar
i'd recommend MSI GF615M-P33 its under 3k, has an AM3 socket and it supports ddr3 ram aswell
just a few shortcomings -
CPU max support : phenom ii x4 945
just 2 ram slots
mATX : u can't put any large gfx card in it
its good for the short term if u don't plan any upgrades but i'll have to change it the next time u upgrade
Cybertonic is offline
PC upgrade [low budge] happy17292 Hardware Q&A 5 18-04-2010 09:48 PM
upgrade dillemma...... spm Hardware Q&A 7 11-04-2010 09:00 PM
Urgent help needed with upgrade. Whistler81 Hardware Q&A 1 09-04-2010 09:48 PM
PC Upgrade help! ojha_riddhish Hardware Q&A 6 27-03-2010 08:00 AM
Free upgrade to 2 Mbps Airtel Broadband!! aashish.joshi Broadband and DTH 2 13-03-2010 10:40 PM
- by c4u
