Old 13-05-2010, 12:59 PM   #1 (permalink)
Hmmmmm
Tenida's Avatar
Talking Help!!!XFX 8600 can handle 22 inch moniter??
I am planning to buy a Samsung 22 inch monitor (2233 SW Model).I has some query:-
1) Can my XFX 8600 GT 256 DDR3 can handle it for playing games/movies in native resolution?
2) If not please recommend me a good graphics card my budget is Rs10k.
3) I have a 1 year old Cooler master 500W smps.Will it be ok to power the new graphics card?
Tenida is offline
Old 13-05-2010, 01:29 PM   #2 (permalink)
GhostRecon's Avatar
Default Re: Help!!!XFX 8600 can handle 22 inch moniter??
XFX 8600 GT 256 DDR3 -
Full HD Video Playback - Yes
Full HD Gaming - No.
For Full HD Gaming get Sapphire/XFX/MSI(Hawk) 5770 GDDR5 1 GB GPU @ 9.5K (10K for MSI HAWK version)
But seeing ur PSU which is I guess Cooler Master Extreme Series, U should opt either for a PSU change (Change to Corsair VX450) or a little lower end GPU XFX ATI 5670 1 GB ~6K
AMD Phenom II X4 925 2.8 GHz | MSI 785GM-E51 | Corsair 2X2 GB 1333MHz DDR3 RAM | Corsair VX550 PSU | BENQ G2220HD 22 inch LCD Monitor | Sapphire Radeon 5770 | Segate 500GB | LG 22X Writer
GhostRecon is offline
Old 13-05-2010, 02:50 PM   #3 (permalink)
bORn To RIse....
rahul.007's Avatar
please first change tour psu if its from cooler master extreme power series(which i guess it surely is)..... get corsair vx450 @ 3.7k.... then you may get a MSI HD5750 1GB GDDR5 @ 8.2K or Sapphire HD5670 512MB GDDR5 Artic Cooling @ 5.3k... but i suggest you to first change your psu to corsair vx450 and then get MSI HD5770 HAWX 1GB GDDR5 @ 10.2k after you have got enough money.... if you don't change your psu then you most probably will have to buy a new rig....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 13-05-2010, 03:04 PM   #4 (permalink)
BSD init pwns System V
hellknight's Avatar
Yup.. it will.. I'm using Cooler Master Extreme Plus 500W on
AMD Phenom II 720 BE
4 GB DDR2 RAM
1 TB Samsung HDD
XFX 4870 1 GB GDDR5
Biostar TA 790 GX Mobo..
without any problem since last 8 months.. go ahead.. If it can handle 4870 then it can definitely handle 5770 as it is built on a smaller (40nm) architecture and uses much less power than 4870..
Moreover, my friend is running this on Cooler Master Extreme Plus 500 W
AMD Phenom II 940 BE @ 3.4 GHz
4 GB DDR2 RAM
1 TB Samsung & 250 GB WD SATA II HDDs
Sony DVD Writer
Cooler Master HAF 922 cabinet
In the scroching 40+ temperature of Gurgaon since last 1 year without any problem
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 13-05-2010, 06:13 PM   #5 (permalink)
Cool Buddy's Avatar
There is unnecessary fuss over the PSU. cooler master PSU is good one and it will definitely handle a graphics card. I don't think people need to waste so much money on PSUs. A 500W cooler master PSU will definitely be able to handle HD 5770. And if it doesn't, you can definitely change the PSU later. It won't get fried at once, it will show unstability like system restarts, game crashes etc.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 13-05-2010, 08:28 PM   #6 (permalink)
Hmmmmm
Tenida's Avatar
Hey friends you are sure that coolermaster can handle ATI 5770 HD 1GB or not plzzzzz tell me frnds....................????
Tenida is offline
Old 13-05-2010, 09:41 PM   #7 (permalink)
bORn To RIse....
rahul.007's Avatar
me not the only person criticizing this psu.... a number of people and not only on TD forum but on other forums too are criticizing this psu because of one question mark that it isn't able to keep up power hungry hardware.... myself own 1(cm extreme power plus 500w)....
psu is the heart of the rig.... why buy it with risk factor.... cm extreme power plus 500w max efficiency is 70% and its non-pfc.... it supplies around 350 w.... suppose your rig draws a steady 350 w... it means your psu is being stretched at its limit.... its being used at its max efficiency.... and thats a really bad thing.... it would mean that some of your components may not be getting the required power to do their job and it would ultimately lead to shortening the life of your components....
4 GB DDR2 RAM
1 TB Samsung HDD
XFX 4870 1 GB GDDR5
4 GB DDR2 RAM
Sony DVD Writer
well bro, problem never comes by knocking on the door.... but when it comes, it blasts the door off.... i would suggest you and your friend to buy a corsair vx 450 too....
Old 13-05-2010, 11:03 PM   #8 (permalink)
Hmmmmm
Tenida's Avatar
@Rahul thanks for explaining me I will buy HD 5770 then definitely I will upgrade smps to Corsair VX550....Thanks again.............
---------- Post added at 11:03 PM ---------- Previous post was at 11:00 PM ----------
And what is difference between modular smps and non-modular one?plzz explain
Tenida is offline
Old 14-05-2010, 12:11 AM   #9 (permalink)
@hellknight, you & your friend maybe lucky till now. that your PC safe. also Extreme Power mostly blows or gets damaged when stretched, i.e. when someone adds a card & tries some heavy games. also these PSU doesn't come with a money back guarantee that it'll get damage. half or more gets damaged & few even loose their system. OP can go & but a Extreme Power, however if he looses his PSU (maybe his system too) we'll have to take the blame for it. so better recommend him a tested & trusted PSU. not one thats most controversial.
@Cool Buddy, yes Cooler Master PSU are good except this particular series. they even launched a new replaced series. Extreme Power Plus but it was of little help as it too was plagued by same problem. also rahul is right. problem doesn't come knocking. you'll know something wrong, only after you fry your motherboard & the proccy. also other things thats getting power from the notorious PSU.
also by later he mayn't have any PC. forget PSU. why keep changing PSU when he can get a good PSU by paying a few couple of hundred bucks more & that will keep his system stable. even in hot Indian weather.
@rahul, good explanation yaar.
@amartya87, for card, get any HD5770. for PSU, get VX450. CX400W will suffice too. but regarding future upgrade, VX450W suites best. VX550W should be considered only if u got the extra money or got plans to buy HD5850 or something like that.
modular PSU's sata cables & the 6 pin & few other cables can be detached if not in use. also it depends on that particular PSU what wries can be detached. cause in some PSU the sata cables & IDE cables comes prefixed. only the 6pin & 8 pin cords can be made loose. not very useful until & unless the user can't tolerate even a single loose cable inside his rig.
Sam is online now
Old 14-05-2010, 01:05 AM   #10 (permalink)
Techie By Heart
mavihs's Avatar
@amartya87
Corsair VX550 is a good choice....keep with it & you won't have to change your SMPS for over 5yrs with new upgrades!
also to know about modular SMPS just google!
Also googleing for CM extrem power PSU will get you good result of fried PSUs!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 14-05-2010, 02:38 AM   #11 (permalink)
icebags's Avatar
all i can tell is my CM E P Plus 500 PSU is doing ok with my rig with following config for last 1.5 yrs:
C2D 8400E
XFX8800GT
Creative extreme gamer S card.
a pinnacle tv card, thats slotted but i dont view tv on it.
2XHDD, 1 DVD W
monitor 19" : 1440X900
my comp runs ~10 hrs everyday , including sometimes when i leave the comp running for 2-3 days running a MMORPG that i play ....
anyways, can someone explain how the psu goes off? does it blasts frying everything up or just it stops working like that ?
also i donno where u got the idea that psu outputs 350W caz its 500W pcu ........ specification clearly says - max OP is 500W @70% efficiency.
i draws whatever current necessary for that. spec says 6amps @ 230V.....(thats a lot)
icebags is online now
Old 14-05-2010, 02:55 AM   #12 (permalink)
hellknight's Avatar
^Agreed..my computer runs 24x7.. it only get switched off when there is no electricity which is a rare case here in Himachal...
@Sam.Shab & @Rahul.007 I've been waiting since last 8 months to see the PSU blow off.. Even overclocked my graphics card, added another HDD, 2 Optical Drive, ran benchmarks such as 3D Mark Vantage & 3D Mark 06, but the PSU was till running nicely.. I don't think that there is any problem with the CM Extreme Plus PSUs.. there would've been some problem in earlier days, but now, I think that they are absolutely fine...
Regarding games :-
Battlefield Badcompany 2 @ Full HD
Crysis Warhead @ 1680x1050
COD MW2 @ Full HD
Moreover, Linux kernel compilation when the CPU was running @ 3.7 GHz..
I ran all the test, the PSU was rock stable.. Now, if you guys can tell me a real person who got his CM Extreme PSU blown up, then I'll think about that..
Old 14-05-2010, 05:31 AM   #13 (permalink)
Cool Buddy's Avatar
I don't disagree that getting a good PSU is a good idea, but why waste money when someone already has a good PSU. Yes, it might be a bit risky, but I've never heard someone's machine get damaged due to a PSU failure, not even on the forum. It's all just a guess that this & that could happen if the PSU fails. Here is what happens if a PSU fails:
I had a frontech PSU which came bundled with my cabinet. I let it be because I still do not have a gfx card. The PSU fan stopped working and the SMPS got real hot. I didn't know till I smelt the smoke coming out of the SMPS. even at that moment my machine was on. I immediately switched it off. Even though the PSU was burnt, my machine was not affected, everything's working fine even after that.
Still if one has the budget one should buy a good PSU, at least, don't blame me later if something does happen.
Nokia 5230 :(
Old 14-05-2010, 10:11 AM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
LISTEN GUYS!!!!!
I've been reading this thread for a while and saw that there is kinda argument going on here on CM extreme series
look it totally depends upon your luck....yeah i said luck!!
I've heard many cases of blowing up of graphic cards due to CM extreme
And I've seen so many cases of power hungry gfx card running all well
SO u see...it depends
also the location matters..i mean where r u staying
is the environment hot or cool enough to make things secure
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 14-05-2010, 10:17 AM   #15 (permalink)
Super Moderator
asingh's Avatar
Okay. Great.
All you guys which are recommending CM E series PSU, it is perfectly all right. Like wise the other lot (including me) are allowed to also not recommend it -- in the sense, if someone ask me which PSU, I will say Tagan/Corsair/Silverstone/FSP, but skip out the CM E series, cause my views are drastically different. If you all managed to run it successfully. Well done. All are open to recommend and suggest.
asingh is online now
Old 14-05-2010, 10:25 AM   #16 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^thats right
I mean whats the reason of taking risks
by just adding around 1k to the price of CM X series anyone can get a LOT better stuff and its SAFE too
--Get Backers
Piyush is offline
Old 14-05-2010, 11:38 AM   #17 (permalink)
bORn To RIse....
rahul.007's Avatar
Originally Posted by piyush120290 View Post
^^thats right
well said.... short and straight to the point....
Old 14-05-2010, 11:44 AM   #18 (permalink)
Hmmmmm
Tenida's Avatar
Thanks for your suggestion friends. I will definitely buy a corsair product because I don’t want to take the risk. I am choosing Corsair VX 550 to secure the future upgrade. And friend I want to purchased good cabinet also I am using cheap frontech cabinet my budget is 5K.Please tell me some good looking cabinets? Thanks in advance.
So final purchased will be—
Monitor-Samsung 2233SW
Graphics Card-Sapphire ATI HD 5770 DDR5 1Gb version
SMPS-Corsair VX550
Cabinet-Advice me….budget 5K
Tenida is offline
Old 14-05-2010, 11:49 AM   #19 (permalink)
bORn To RIse....
rahul.007's Avatar
for your cabby, cooler master 690.... and buy corsair 550 only if you would be doing future upgrades else corsair 450 would suffice....
Old 14-05-2010, 11:53 AM   #20 (permalink)
Wise Old Ghoul
Piyush's Avatar
exactly
i think 690II advanced is out there
i saw one at SMC international
but no idea about the price
--Get Backers
Piyush is offline
Old 14-05-2010, 11:58 AM   #21 (permalink)
LISTEN GUYS!!!!!
earlier i already mentioned, Extreme Power doesn't come with any guarantee it'll go up. just some breaks down if load applied.
^^thats right
who needs add 1k? simply adding 200 bucks more or so will fetch you a better PSU, like FSP Saga II 500W/Seasonic 380W/Corsair CX400W & a hell lot from Silverstone & Tagan. and all these are enough to run a HD5770 with a well organised system.
Sam is online now
Old 14-05-2010, 12:01 PM   #22 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^yea i know
i was giving just a rough idea
--Get Backers
Piyush is offline
Old 14-05-2010, 01:10 PM   #23 (permalink)
hellknight's Avatar
Regarding cabby, go for CM 690 II or you can also get CM 690 for as low as 4k..
And regarding PSU, Corsair is awesome, I agree, but CM Extreme is running fine too.. I guess that it is CM Extreme Plus.. The thing is that, I live in Himachal. People here are not as tech savy as you guys. Recommending them a PSU above 1.5k is huge.. so forget PSUs like Corsair, Tagan etc which are above 3.5k I guess..
For eg, One of my friend who as a Intel Core 2 Quad Q6600, 4 GB RAM, 1 TB+250 GB HDD is looking for getting a new card like 5770 or above.. But he doesn't plays even a single game on his PC, he just competes with my group..
He has about 1.3 TB HDD which is filled almost completely 90% with Porn.. so when I suggested that he should go for either CM Real Power or anything else, he was reluctant..
Old 14-05-2010, 05:57 PM   #24 (permalink)
bORn To RIse....
rahul.007's Avatar
o koi nhi yaar....
his rig must be HOT....
Old 14-05-2010, 10:14 PM   #25 (permalink)
Cool Buddy's Avatar
Well, no suggestions anymore, but just one point. The thread starter already has corsair CM PSU, so there's no question of adding 200 bucks or 1000 bucks as many suggested. He would have to buy a new PSU by paying the whole Rs. 3700. So it isn't a question of 100 bucks but 3700 bucks. Anyway, now that he doesn't want to take risks, it's alright.
Nokia 5230 :(
Old 14-05-2010, 10:17 PM   #26 (permalink)
icebags's Avatar
and the answer it YesNo !!!!
Yes for movie and No for gaming.
Old 15-05-2010, 12:53 AM   #27 (permalink)
who needs 3700? he can go for FSP Saga II 400W or Gigabyte 460W. both will be able handle a HD5770, provided the rest of the system is light. and both cost below 2.5k. the FSP is available for as low as 2k in some places. or he can go in with a Corsair CX400W, if he needs peace of mind.
Sam is online now
Old 15-05-2010, 08:04 PM   #28 (permalink)
Cool Buddy's Avatar
Well, now that there are so many suggestions, Let me ask something too. I will be buying an HD 4670 soon. Since the card consumes <60W, I don't think I'll need to go for such PSU. What PSUs can I find within a 1000 bucks. My existing PSU is not good enough for any gfx card as i have already written it is a frontech.
Nokia 5230 :(
Old 15-05-2010, 10:00 PM   #29 (permalink)
within 1000 bucks you'll get same stuff different names. cheapest yet good PSU is FSP Saga II 350W. or desi PSU like VIP 400W Gold (nothing golden about it). VIP will ost 1300-1400. FSP 1500, but worth it.
Sam is online now
Macbook pro 13 inch or dell xps 13 inch coolest111 Hardware Q&A 12 07-05-2010 01:46 AM
Suggest a 19-20 inch LCD monitor for gaming meetdenis Hardware Q&A 6 13-03-2010 06:17 PM
Need help selecting 22 inch LCD monitor Red_Baron Hardware Q&A 11 26-02-2010 07:54 AM
can any one suggest me a good 15 inch lcd moniter under 10k ASH18MARCH TVs / Monitors 17 18-08-2005 10:36 PM
- by c4u
