12-05-2010, 04:02 PM
throttle press fire !!
Gaming Pad :)
Hello guys,
Well, the desktop config u helped me with earlier is stil not delivered to me by hardware vendor, asus sound card is not available. anyways, this thread was an attempt to know which gaming pad i should buy, keeping in mind that I want to play Street Fighter 4. Budget is maximum upto 4K. cheers
12-05-2010, 04:11 PM
Living to Succeed
Re: Gaming Pad :)
I have used some gamepad but the best and favourite one is XBOX game pad.... its simple great to play with it
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
12-05-2010, 04:27 PM
15.0 GHz
Re: Gaming Pad :)
^+1 for XBOX Game Pad.
It fits in your budget and is good. Also various gamepads are also available from Logitech and Twinshock.
13-05-2010, 04:20 PM
Re: Gaming Pad :)
^+1 for XBOX Controller (Game Pad)
Awesome Game Pad.
Everything is Possible
13-05-2010, 05:57 PM
Re: Gaming Pad :)
I haven't used one but often seen people recommending Xbox gamepad at various places. So I think it is a good controller. Logiitech wireless is available for around Rs. 2500. You can consider that too as logitech's input devices are known for their accuracy.
13-05-2010, 06:03 PM
Living to Succeed
Re: Gaming Pad :)
i have used Logitech Rumblepad with 2 vibrators... i dont rate it at par with Xbox.... xbox controllers are more better... accurate... and easy to get used to...
13-05-2010, 08:09 PM
15.0 GHz
Re: Gaming Pad :)
I say no Wireless for Gaming. It will LOOT you in batteries.
13-05-2010, 08:26 PM
Re: Gaming Pad :)
Dilip, when friends here recommended xbox360 controller i was like, REALLY ???? ... battery???? but then i thought mayb they supply a charger too ffor the batteries they provide, which i hope they provide. like sony cybershots... But, even i m thinking now.. SAY NO TO WIRELESS ... guyz know of any wired gaming pad ??? even the new keyboard n mouse that I have ordered is a wired one > Razor adder . arctosa.... have a logitech sireless mouse, n i know battery is an issue.
13-05-2010, 09:01 PM
Reverse Engineering rocks
Re: Gaming Pad :)
The X-Box controller is the best...Go for it .....
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
14-05-2010, 09:54 AM
Living to Succeed
Re: Gaming Pad :)
Xbox controller comes both wired and wireless.... u can go for Xbox and enjoy gaming
14-05-2010, 10:48 AM
Wise Old Ghoul
Re: Gaming Pad :)
+1 for Xbox controller
Almost all games recommend these XBOX controllers if required any
14-05-2010, 10:59 AM
15.0 GHz
Re: Gaming Pad :)
^ as said XBOX controllers come in Wired & Wireless both models. If you buy wireless then you have to spend over batteries and if you choose wired then it will be great.
and BTW. my name is Varad
14-05-2010, 11:06 AM
Wise Old Ghoul
Re: Gaming Pad :)
^^y r u pointing me dude?
14-05-2010, 11:25 AM
Re: Gaming Pad :)
lol piyush.. varad i guess dilip is after all your fathers' name . I'l go for the wired xbox controllers then. which GOOD games can we play with them on PC, i cud recollect street fighter 4 and fifa10.
14-05-2010, 11:52 AM
Living to Succeed
Re: Gaming Pad :)
Well i started with Fifa and bought it mainly for that. then i started playing Gears of war with it and faced problem aiming with the controller. But then after some days of playing i am facing problem not playing with the controller. Now i cant imagine playing without it.
Go for any game and even if u have played it before ... you will enjoy it again
14-05-2010, 09:46 PM
Re: Gaming Pad :)
thanx guys.. i'l stick to wired xbox  ... m a fan of microsoft products  ... though i did chek out the logitech pad which u mentioned ...logitech products are very very reliable..
Intel Core i7 930;GA X58A-UD3R;Corsair 3x2GB 1600MHz
HD5850 1GB GDDR5;cabinet-Asus Vento 3600;DELL SP2309W
Razer Arctosa;Razer Death Adder;
Altec lansing 2.1 MX5021;Asus Xonar DX for MX5021
14-05-2010, 10:13 PM
Re: Gaming Pad :)
ppl hate wireless mouse for gaming caz of the wireless lag. same is true for wireless controller , there has to be some lags.
however if you don't play fast games (like those shooing FPS/TPS) you may not feel that bad.
