Old 11-05-2010, 10:49 PM   #1 (permalink)
Default help for upgrade!!
hi friends... i have bought a intel core2 quad 2.66ghz 4mb processor...
and i need help to choose a compatible mobo of any brand for this pro....i already have 2gb ddr2 ram , so decided to use the same...also iam prefering to use my old 9400gt for now and then later upgrade it,.. my budget for mobo is rs.2500.. pleas hhelp...
thanks in advance
jeymagnettron is offline
Old 11-05-2010, 11:32 PM   #2 (permalink)
Default Re: help for upgrade!!
look out for G31 mobos. they will set you back by 2.2k or so, depending on which you pick. can opt for P41 chipset based mobo. but will cost more. well stick to G3* series chipset mobo.
Sam is online now
Old 12-05-2010, 06:22 AM   #3 (permalink)
which suits better? intel or gigabyte boards ..... also can you say the present price of dg31pr
Old 12-05-2010, 09:40 AM   #4 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Gigabyte Intel G31 Chipsets would cost you around 2.3k and G41 Chipsets around 2.5k to 3k (In both the case price depends on the model you pick up)
You can go for ASUS P5KPL series boards starting from 2.2k
Gigabyte, ASUS etc of-crs better than Intel chipsets. Well at this budget I will suggest to go for ASUS P5KPL series boards. Pick up one that falls within your range.
---------- Post added at 09:40 AM ---------- Previous post was at 09:36 AM ----------
DG31PR would cost you approx 2.5k
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
- by c4u
