Old 11-05-2010, 05:54 PM   #1 (permalink)
Default suggest me a good tv tuner card
hi,
suggest me a good internal tv tuner card.
it should work with winxp/vista/win 7
dilipc is offline
Old 11-05-2010, 08:57 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: suggest me a good tv tuner card
budget?
7/char
VarDOS is offline
Old 12-05-2010, 11:41 AM   #3 (permalink)
around 2.5k- 3k
dilipc is offline
Old 12-05-2010, 11:47 AM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Although you did say Windows Im going to warn you in advance that if you ever plan on using a Linux install and want it to work in there then make sure you buy a chipset which is recognized. if you don;t plan on using it in Linux ever than disregard this advice.
External TV Tuner boxes can work with just the monitor if thats what you need but will lack the option to rcord anything.
For Internal Tv Tuners I have had a good experience with Pinnacle.
FilledVoid is offline
Old 12-05-2010, 12:02 PM   #5 (permalink)
laborare est orare
Cilus's Avatar
go for the pinnacle pctv pci internal tv tuner card. It is really good card priced at 2.7k with 1 yrs of warranty.
Apart from TV watching, it can record TV shows, can take input from your analog sources (like your miniDV, HI-8, Digital-8 handy-cams), and record it either MPEG and Mpeg4 (DivX) format.
It is also having a FM tuner.
Check the link for details.
Phenom II X6 1090T@3.6GHz|8 GB RipjawX 1600 MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|HD 6870CF|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|G2220HD|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Corsair HS1A|APC1.1KVA
Cilus is online now
Old 13-05-2010, 10:19 AM   #6 (permalink)
thanks for the suggestions. will go for pinnacle.
dilipc is offline
Old 13-05-2010, 09:17 PM   #7 (permalink)
bajaj151's Avatar
For External : Go for UMAX
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is offline
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
Suggest Me A Good Headphone.....(1k-1.5k) sundar07 Audio 1 12-04-2010 09:14 PM
Suggest a high quality tv tuner card sakthirajesh Hardware Q&A 0 05-04-2010 12:03 PM
[Urgent]Looking to buy good Flashdrive/Pendrive (16GB or above) kanishka Hardware Q&A 7 31-03-2010 07:26 PM
Suggest me a Best PCMCIA Tv tuner card symbiguy Hardware Q&A 2 03-04-2007 05:08 PM
- by c4u
