Old 10-05-2010, 05:59 PM   #1 (permalink)
Default Burnt 9600 GT
I bought an XFX 9600gt 512 in december last year.And a few days back it blew up burning my mother board in the process.The motherboard warranty is definitely voided.
I know that graphic card manufacturers do not replace bunt products,but the customer care guy says it burnt out due to the card being seated in the PCI-e slot wrongly.
Here are my doubts-
1-If a card was seated improperly,would it function for 6 months without a single blue screen,crash or other issues?
2-The card was bought for watching movies.If a card such as the 9600 gt blows up while playing movies 2-3 hrs a day,what cahnce to the high end cards have?
3-I had a 500w PSU which meets the requirements specified by the manufacturer.Any problem there?
Please help me out.I already have a hole in my pocket replacing my motherboard.
neerajmenon is offline
Old 10-05-2010, 06:53 PM   #2 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Re: Burnt 9600 GT
i think its either ur mistake or motherboard fault
gopi_vbboy is online now
Old 10-05-2010, 08:47 PM   #3 (permalink)
Here are my doubts-
was your card sing sloted?
also whats your PSU? 500W says too little. brand & the particular series is needed.
Sam is online now
Old 10-05-2010, 09:18 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
^yes, it could also be happened if your PSU is local. Some voltage fluctuation or increase in the current flow or over heating due to summer...
VarDOS is offline
Old 10-05-2010, 09:22 PM   #5 (permalink)
Cool G5's Avatar
I too doubt the PSU.
Cool G5 is offline
Old 10-05-2010, 10:33 PM   #6 (permalink)
Wise Old Ghoul
Piyush's Avatar
PSU must be local
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 10-05-2010, 11:34 PM   #7 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
From his name I think he is from kerala.No one uses branded PSU here all are using 500bucks SMPS.Also 9600GT needs PCIe connector.So PSU might be the culprit.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 11-05-2010, 03:27 AM   #8 (permalink)
Guys,my smps is a VIP-500w.
What is a PCI-e connector?Are you refering to the slot on the motherboard?Or a connector to be connected to the power supply?
Old 11-05-2010, 10:00 AM   #9 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Then Its not PSU problem.You got a good PSU.PCIe connector is the power supply to the graphics card.Its a 6 pin connector.If your card is a low power edition, then you wont need PCIe connector.But in case your card is normal and you ran it with out PCIe connector, there is a possibility of a disaster.
ajai5777 is offline
Old 11-05-2010, 10:08 AM   #10 (permalink)
Super Moderator
asingh's Avatar
It is highly probable due to the VIP 500W PSU. That would not sustain clean / ripple free power, required for the high pull which the 9600GT would require. That VIP is desi, and is bad.
asingh is online now
Old 11-05-2010, 11:39 AM   #11 (permalink)
15.0 GHz
VarDOS's Avatar
^ +1
10/char
VarDOS is offline
Old 11-05-2010, 01:50 PM   #12 (permalink)
PSU is the main cause of your burnout.
+1. VIP or Zebronics or iBall. 500 or 600W. they can't b trusted. specially when PC includes a graphics card. add to it, it requires external power.
Sam is online now
Old 11-05-2010, 04:09 PM   #13 (permalink)
No the card id not have an external pci-e connector for power.Still the PSU's fault?
I am screwed either way right?No chance of a replacement?
Old 11-05-2010, 05:29 PM   #14 (permalink)
yes. don't go by the names. GOLD or Platinum. all these are bad & not upto the mark of international standards. so it matters little if you got 500W PSU from VIP or other sub par brand. it'll go bad.
Sam is online now
Old 11-05-2010, 08:19 PM   #15 (permalink)
15.0 GHz
VarDOS's Avatar
^as said, never trust the names. I only trust PSU's from Corsair, Antec, Cooler Master - Extreme Power. Even though I own a Local PSU .
I think you are screwed, no chance of replacement (Its a physical damage)
VarDOS is offline
Old 15-05-2010, 12:15 AM   #16 (permalink)
Hi menon,
I too had similar incident with my ATI card. I don't think any of above is cause. I think it is the gfx card fan! As it was the case with me. My MSI card's fan got stuck due to dirt or some other reason. I myself checked that. these cards don't have any sensing with their fans so that one would know about card's over heating. Actually there was no fire hazard in my case, it was just the graphics processor burnt off. I think same happened to you. My PSU is running fine (I am running my computer w/o graphics card).
rahulkay is offline
Old 15-05-2010, 08:44 PM   #17 (permalink)
Cool Buddy's Avatar
Do take your card to the service center, just in case you get lucky.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 15-05-2010, 09:56 PM   #18 (permalink)
there is no chance on RMA if thats what ur trying to tell....repair may be hard...if its a few blown resistors they could fix it...high res pics please ?
Win hardware worth 11k!!
rajan1311 is offline
Old 16-05-2010, 12:31 AM   #19 (permalink)
cooldip10's Avatar
I have got my gfx card burnt twice and my smps blew too both the time. I had to fight a bit and got both replaced.
But the smps that I got in replacement was pathetic. I had to buy a new one though. Due to Monetary constraints, I had to opt for a Zebronics 500W. Luckily it is still working.
Everything is Possible
cooldip10 is offline
which make of 9600 GT to buy ? codesuperking Reviews 26 25-05-2008 12:27 AM
[URGENT!!] Adding boot informaton to burnt vista DVD-R fun2sh Software Q&A 4 12-11-2007 11:13 PM
Cable Burnt Due To hard disk AMITAGARWAL02 Hardware Q&A 6 30-09-2007 12:35 PM
ATI Radeon 9600 and ASUS K8N compatibility - urgent!!! sakumar79 Graphic cards 5 09-02-2005 02:44 PM
Radeon 9600 Pro Vs. Fx 5600 mad_gundam Graphic cards 6 17-08-2004 06:35 PM
- by c4u
