Old 10-05-2010, 02:00 PM   #1 (permalink)
Default A processor for Gigabyte GA G31M ES2L Motherboard
Hello,
I have a Gigabyte GA G31M ES2L Motherboard which needs a pinless processor (whatever that is). Please suggest a medium low end processor that is compatible with the motherboard.
Thanks in advance.
technubie is offline
Old 10-05-2010, 03:11 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: A processor for Gigabyte GA G31M ES2L Motherboard
Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™ 2 Quad processor/Intel® Core™ 2 Duo processor/ Intel® Pentium® processor Extreme Edition/Intel® Pentium® D processor/ Intel® Pentium® 4 processor Extreme Edition/Intel® Pentium® 4 processor/ Intel® Celeron® processor in the LGA 775 package
---------- Post added at 03:11 PM ---------- Previous post was at 03:10 PM ----------
Its the LGA775 (land grid array) package. The CPU connector is pinless.
asingh is online now
Old 10-05-2010, 09:09 PM   #3 (permalink)
Originally Posted by technubie View Post
Hello,
Thanks in advance.
AMD processors got pins. Intel pins don't have pins. what processor u pick up.
Sam is online now
Old 11-05-2010, 01:57 PM   #4 (permalink)
laborare est orare
Cilus's Avatar
Intel processors are placed in a LGA package which means "Land Grid Array" whereas AMD processors use technology called "Pin Grid Array". LGA design takes the advantage of Surface mount Technology or SMT, which enables components to be directly mounted directly onto the surface of PCB (Printed Surface Board). So Intel processors does not have any pin
Cilus is online now
Motherboard essentials flamore_54 Hardware Q&A 10 27-04-2010 02:48 PM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Built ur own pc. rajas700 Tutorials 3 10-09-2005 09:33 AM
- by c4u
