I have Silan SC92031 Fast Ethernet Adapter. Since I have formatted my PC a month ago, I have been experiencing a weird problem. I have installed WinXp SP2. OS seems to have some problem with the driver installed for the Lan Card. Xp sometimes accepts the driver and the internet would work fine. But, on those bad days, when I turn on the system, Ethernet Controller would be found out as a new Hardware and even though I install the driver (the same which just works fine) OS would not accept it as a valid driver and I can not use the internet. I do not know what is the problem.Such a problem has never occurred before. This driver has worked fine before. I don't know whether this is a h/w or a s/w problem? Can anybody shed some light upon the problem?
Any help would be appreciated.
Thanks.
-Nilay
