Originally Posted by swapraj
not buying new one just want to upgrade. my PC configuration is
p-4 2.93 Ghz
2 GB DDR2 800 Mhz
Asus P5N73-AM (256 MB nvidia onboard graphics)
17 CRT monitor
80 GB HDD
do you play any games, if no then you can go for the LCD as you be able to watch movies in HD & you'll have a better experience!
Also soon intel will be changing there sockets again so i recommend you save some more money & go for an AMD setup as it'll give you more bang for buck/value for money!
Also Nvidia will be taking out the Fermi based entry lelvel cards which are going to be way more better than the current entry level cards!
If you decide to buy the card now then i would recommend you go with an ATI card as they have better performance & also value for money & also better visuals/graphics!
