Old 07-05-2010, 03:21 PM   #1 (permalink)
Default Querry in event log
i am gtg a regular entry (error) in windows system log as shown below:--
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Unknown Error
Processor ID: 1
my processor is amd athlon and the os is windows 7
can any one explain what does it mean?
thanks in advance
murphyker is offline
Windows Log On Screen mati17 Software Q&A 3 14-04-2010 02:45 PM
Check Your PC for Shutdown and Startup Log - Forensic Way ritesh.techie Technology News 8 26-02-2010 06:23 PM
The system could not log you on. The server authenticating you reported an error (0xC jayanbhm Software Q&A 1 12-02-2010 03:24 PM
Not able to start the Task Scheduler or Windows Event Log Service alsiladka Software Q&A 2 14-03-2008 12:29 AM
- by c4u
