Re: Hard disk data recovery........?
@test1234xyz
first don't format the drive!!.
and also don't put any data to that partition as this may overwrite the sectors!,
as this reduces the probability of recovering data..
first try with data recovery software's.. like easy recovery professional,active partition recovery,recover4all,etc...
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
