Old 07-05-2010, 01:21 PM   #1 (permalink)
15.0 GHz
VarDOS's Avatar
Default OverHEATED!!!
Hi Friends,
I just wanted to know is this temperature good for the following RIG?
Intel Core 2 Duo E4500 (Not OC'd) - Stock Cooling
Intel D946GZis
2GB RAM
This is the Idle temperature.
Don't you think it is over-heated for a Decen't rig.
And whenever I run CS 1.6 it raises to 60 - 62 Degree Celsius and the Keyboard + Mouse just freezes and only the monitor shows the motions and HDD LED and DVD LED starts running abnormally.
What should I do?, I applied Thermal Paste but the temperature is the same.
VarDOS is offline
Old 07-05-2010, 01:29 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: OverHEATED!!!
YUP its Fine
just check out the link
http://www.pantherproducts.co.uk/Art...eratures.shtml
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 07-05-2010, 03:35 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Default Re: OverHEATED!!!
Else check this link.
http://www.techenclave.com/cpu-mobo-...ed-165984.html
asingh is online now
Old 07-05-2010, 03:40 PM   #4 (permalink)
15.0 GHz
VarDOS's Avatar
^LOL, that's my own thread.
@satyamy thanks, but what about my CS 1.6 problem?
VarDOS is offline
Old 07-05-2010, 05:09 PM   #5 (permalink)
Super Moderator
asingh's Avatar
I know, it is. That is why I posted the link there. (see my reply there)
SATA HDD gets overheated! =CrAzYG33K= Hardware Q&A 2 01-07-2007 09:10 PM
Help! CPU overheated. ~Phenom~ Hardware Q&A 3 14-06-2007 12:46 PM
CPU remains overheated...........tried many options!!!!!. ranjan2001 Hardware Q&A 63 23-03-2007 11:52 AM
CPU overheated anilmail17 Hardware Q&A 5 01-01-2007 07:19 PM
Overheated!!! saketkutta Hardware Q&A 18 10-06-2006 09:58 PM
- by c4u
