Old 07-05-2010, 12:18 PM   #1 (permalink)
aneek's Avatar
Unhappy Need to buy a laptop in about 40K - 50K
Hi all,
Recently my newly upgraded pc got brunt down. So I decided to buy a new laptop. My range would be in 50K.
Can you tell me which laptop I should go for. I'm thinking about HP and Dell.
But there is something that bothers me. My friend got a new HP DV series laptop that doesn't recognize the modem.
I'm a web developer so I need to install Adobe CS4 maybe CS5 later also sometime I love to play games but not to often. The games I used to play is FIFA 10, Farcry 2 types of graphics.
As a php developer I love to be in Open Source. All the laptops will come with Windows 7 Preloaded. Can I have one laptop with no Os in it so that I can Install Ubuntu in it.
Please give me your suggestions as soon as possible....
aneek is offline
Old 07-05-2010, 04:43 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Need to buy a laptop in about 40K - 50K
Acer 5740G-6979 @ 43k
For details check other posts about laptop. I have suggested this to many more in this forum and some performance review is also there.
Basic Info
Intel Core i5 420M 2.23 GHz (Turbo Boost 2.57 GHz, 3 MB L3 Cache)
4 GB 1066 MHz DDR3 Ram
500 GB SATA 5400 rpm HDD
1 GB GDDR3 ATI Radeon HD 5650 with DirectX 11
15.6 Acer Crystal Clear Display with max res 1366 X 768
4 USB port, Web Cam 1.3 Mpx
5.1 Dolby Digital, true Surround HD
Gigabit Lan, Modem and Wi-fi b/g/n
Battery Life 3 Hrs
Weight 6.16 lb
Cilus is online now
Wanna buy a Laptop 40-45K rohit2hell Hardware Q&A 1 27-04-2010 01:31 PM
Help me find a laptop for Rs 30,000 roccstar2 Hardware Q&A 0 26-04-2010 05:59 PM
Prob in installing XP on HP dv4-1204TU Laptop bizzare_blue Software Q&A 1 01-03-2010 12:56 PM
Help me select a laptop please... iamall Hardware Q&A 4 16-02-2010 09:23 PM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
- by c4u
