Old 05-05-2010, 10:11 PM   #1 (permalink)
soyab0007's Avatar
Default Dis Boot Failure Insert System Disk & Press Enter
from yesterday my seagate HDD not working..
It gives me error
"Disk Boot failure Insert System Disk & press Enter"
i have replugged the cable & check my HDD on my friend PC but same problem..
HDD not detecting in bios as well.
I stay in mumbai.. And there is Accel frontline service centre in sakinaka.. Where they take seagate HDD..
But my friend is saying that u have to send email to seagate for some no..
& is there any way to recover a HDD..
Bcoz there are photos which are most valuable to me...
soyab0007 is offline
Old 06-05-2010, 06:36 AM   #2 (permalink)
kanhadey's Avatar
Default Re: Dis Boot Failure Insert System Disk & Press Enter
Ur disk has gone kaput.
Is it under warranty? Your friend might be telling of something like complaint number. Don't u have any tel no. of the service centre(try 2 ask from any comp vendor). They wil replace it, but i think they dont recover data. U have 2 luk 4 some data recovery sol. near ur area. Have u asked the dealer the same.
Is it physically crashed and not showing even on bios?
If not u can give REMO Recovery pro a try using any other pc.
kanhadey is offline
Old 06-05-2010, 10:39 AM   #3 (permalink)
soyab0007's Avatar
but when HDD is not detecting how can we recover..
Old 06-05-2010, 08:57 PM   #4 (permalink)
boeing_737's Avatar
Well... you can try to boot into Ubuntu as a Live CD. Then check if your hard drives show up... if they do, you may have some chance of recovering the data..
Aerodynamically, a bumblebee shouldn't be able to fly. But the bumblebee doesn't know that, so it goes on flying anyway... ;)
boeing_737 is offline
[Windows] FreQuently AsKed ProBlems WITH SoluTions... Vishal Gupta Software Q&A 254 25-05-2012 11:44 AM
Ubuntu gutsy Gibbon 7.10 help needed ! FilledVoid Open Source 11 19-11-2007 06:35 PM
Use "Windows" your own way ! rajkumar_personal Software Q&A 6 26-02-2005 11:40 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
Boot INI Option Reference go4inet Software Q&A 5 18-10-2004 12:07 AM
- by c4u
