Old 03-05-2010, 09:33 PM   #1 (permalink)
Default Plz Help Me to Buy a 5.1 Sound System
I want to buy a decent 5.1 sound system within range of Rs.4500. Plz help me to select one......
kangkan is offline
Old 06-05-2010, 08:44 PM   #2 (permalink)
Will Power
TheLetterD's Avatar
Default Re: Plz Help Me to Buy a 5.1 Sound System
Altec Lansing VS3251 was the model i think...It was something like that but i dun remember the exact model..I bought it around a year back..Its around 3.8K.
Pros:-
Extremely crisp sound....
Awesomely light speakers..
Nice build quality....
Sophisticated/professional like design
Cons:-
Weak Remote reciever (no more than 10 feet far)...
3.5 mm Pins so only PC for full surround sound..
Soft Bass..BUt if u put it too High it gives a Pinching type sound of bass..not a deep one( ull understand wen u listen to it once)
TheLetterD is offline
Old 07-05-2010, 12:20 PM   #3 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Creative Inspire T6100 @ 3.7k I bought it 6 months back.
Pros:
Crystal clarity sound
Tweeters and midrange drivers
18W horizontal centre speaker for clear diologues in 5.1 movies
Wall shaking bass
Good build quality and styish look
Cons:
No wired remote.Volume control is attached to Front Right speaker.
Bass is slightly over powering after the bass level 2 in subwoofer.
P.S :
You should pair it with a creative SB series Sound card for best results.Atleast a SB 5.1 vx @ 1k (I use that and the combo rocks).If you use it in an onboard audio, It'll be played crap.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Nokia 5233 or nokia 5235, ...which to buy plz help MCDC Buying Advice 4 15-04-2010 04:17 PM
Suggest me a 5.1 sound card onlytanmoy Hardware Q&A 0 07-04-2010 10:09 PM
Will have to buy a 5.1 speaker system sabret00the Hardware Q&A 12 19-12-2006 08:03 AM
BIOS updates - How to recover sagargv Tutorials 16 22-03-2006 09:35 AM
help.about blue screens.random messages.no hibernation hippi QnA (read only) 7 05-01-2006 07:52 PM
- by c4u
