Old 03-05-2010, 06:16 PM   #1 (permalink)
Default URGENT : plz help me buy a power supply and a cabinet
since my power supply burned out the day i upgraded my pc ... i m planning to buy a new one ... plz suggest good a psu and a good pc case under 6k ... my pc config is:
amd phenomIIX4 925
asus m2n68
1.160TB hdd
19" lcd
3gb ram
ATI sapphire hd 4850 512mb
i dnt over clock so plz dnt suggest very expensive power supplies..
guys plz donot exceed the total budget of rs 6000
guru280789 is offline   Reply With Quote
Old 03-05-2010, 06:21 PM   #2 (permalink)
pulsar_swift's Avatar
Default Re: URGENT : plz help me buy a power supply and a cabinet
CM ELite 310 - Rs 1700
CORSAIR VX 450 - 3800
Total comes to Rs 5500
If you want spend exact Rs6K, then upgrade the cabinet to NZXT Gamma @ 2.1K - Total comes to Rs 5900
pulsar_swift is offline   Reply With Quote
Old 03-05-2010, 06:23 PM   #3 (permalink)
but will a 450w psu support my system cause i was using a cheap 550w psu nd i burnt it twice in the past 4 days ... rite now i m using the same but widout my gpu
Old 03-05-2010, 06:30 PM   #4 (permalink)
CORSAIR VX 450 can support HD5770. HD4850 power consumption > HD 5770 ? I think VX 450 would support HD4850.
Else go for CORSAIR VX 550 @ 4.5 -4.8 K
Could you disclose which PSU you were using which burnt out ?
Old 03-05-2010, 06:48 PM   #5 (permalink)
some cheap comapany called fuel ... i was all out of cash and i didnt really know the importance of a gud psu wen i bought it
Old 03-05-2010, 06:49 PM   #6 (permalink)
BE FREE
the cheap 550w psu - means non pfc with about 300-350w ouput, so gone kaput,
go for vx 550w, even if you think you would lose 10-20% efficiency it would work for 3-5 yrs easily.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Old 03-05-2010, 06:50 PM   #7 (permalink)
how are the psu's 4m cooler master ?? i asked a shopkeeper 4 da prices nd he told me dat he has a coolermaster combo for rs 5750 dnt really now wat cabinet nd psu he is giving me
Old 03-05-2010, 06:55 PM   #8 (permalink)
if he is giving it as a combo then it has to CM Extreme Power series. Members on digit suggest to stay away from Extreme Power Series. Check if he is offering Real Power or GX series as part of that combo.
Old 03-05-2010, 06:57 PM   #9 (permalink)
i ll surely do dat ... thnks a lot
Old 03-05-2010, 06:59 PM   #10 (permalink)
BE FREE
^ forget about it, it would definitely CM Extreme ones...........
better get nzxt gamma cabby for 2-2.2k and Corsair vx 450w, if you could increase the budget get vx550w for 4.8-5k, or CM GX 550w for 4.5K.
Old 03-05-2010, 07:46 PM   #11 (permalink)
buddy, the op's question was VX 450 can it run HD4850 ?
CM Gx550W or CoRSAIR VX 550W which one is better ?
Old 03-05-2010, 08:57 PM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
CORSAIR VX 550W is better
also regarding power consumptions
4850 -250W
5770-200W
both at full load
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 03-05-2010, 09:13 PM   #13 (permalink)
BE FREE
both are good, however vx 550w is time tested and gx 550w is new in the market and 1/2k less than the former and I was saying of 550w keeping in mind of any future upgrades and efficiency loss in time........
Old 03-05-2010, 09:24 PM   #14 (permalink)
Efficieny loss ? It doesnt impact the output right ? It only impacts the amount of power it takes from the plug/terminals to produce the rated output
Old 03-05-2010, 09:27 PM   #15 (permalink)
BE FREE
it does effect output, and I think our friend asigh can throw more light on it.........
Old 03-05-2010, 09:30 PM   #16 (permalink)
PhotonAttack
DigitalDude's Avatar
get the corsair vx550 it has one 6 pin and one 6+2 pin pci-e connector whereas the vx450 has only one 6 pin connector. so you would be better with the vx550 for future graphic cards
though you can convert a molex connector to another pci-e connector that's not a perfect solution
anyway a vx450 will handle the hd4850 fine. get it if you are totally limited by the budget of 6k.
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is online now   Reply With Quote
Old 03-05-2010, 09:33 PM   #17 (permalink)
BE FREE
a basic tutorial-
http://in.coolermaster.com/tutorial/...hp?language=en
Old 03-05-2010, 09:50 PM   #18 (permalink)
Super Moderator
asingh's Avatar
Efficiency is the ratio of output : input. As the PSU gets hotter the efficiency ratio can come down. One may argue that the PSU will continue to punch out the required output. That is not always the case. If not good quality over prolonged period errors start to crop up, in the form of ripples, and inefficient power throughput.
asingh is online now   Reply With Quote
Old 03-05-2010, 10:12 PM   #19 (permalink)
BE FREE
^ so in simple words it would not output the required wattage............
---------- Post added at 10:12 PM ---------- Previous post was at 09:52 PM ----------
http://www.corsair.com/appnotes/default.aspx
more articles-------read this..
AN805: Why a High Quality PSU is an Essential Purchase
Old 03-05-2010, 10:50 PM   #20 (permalink)
Thanks mate. very informative
So guru, you have your answer VX 450W will handle HD4850. If have the money then VX550W would add more headroom for future upgrades
Old 03-05-2010, 11:16 PM   #21 (permalink)
Super Moderator
asingh's Avatar
VX550W = better. Two PEG connectors.
Old 04-05-2010, 06:28 PM   #22 (permalink)
well just wanted to know wen the psu says 550w does dat mean its output is 550w or is its input 550w thus the corresponding output.. considering the efficiency?
Old 04-05-2010, 06:50 PM   #23 (permalink)
Section Moderator
gopi_vbboy's Avatar
^^dude input cant be 550w on no load...so its nothing but max o/p supported from psu...its capable of driving 550w load...thats wat it mean
gopi_vbboy is online now   Reply With Quote
Old 05-05-2010, 08:05 AM   #24 (permalink)
Buddy check the corsair website, you will get to know
http://www.corsair.com/products/vx/default.aspx
Phenom II X4 955BE|CM Hyper TX3|ASUS M4A785TD V EVO|Sapphire HD5670 512MB AC|4GB CORSAIR VS2GB1333D3|500GB WD Green|320GB Seagate|CORSAIR VX 450|
CM Elite 310 + 4 CM 120mm fans (3 Intake 1 Exhaust)
Old 07-05-2010, 09:31 PM   #25 (permalink)
Hey Guru,
Did you buy PSU and Cabinet ?
Old 02-06-2010, 10:59 AM   #26 (permalink)
hey i bought a psund a cabinet.... i bought 600watts CM nd i bought zebronics warhawk
thnks 4 ur help guys... nd srry 4 da late reply had my exams goin on
Old 02-06-2010, 11:17 AM   #27 (permalink)
Super Moderator
asingh's Avatar
Which CM PSU..?
Old 02-06-2010, 11:31 AM   #28 (permalink)
extreme plus
Old 02-06-2010, 12:56 PM   #29 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
extreme plus
Sorry to hear that
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 02-06-2010, 12:58 PM   #30 (permalink)
Super Moderator
asingh's Avatar
extreme plus
And you seriously followed the advice we gave here...? Who recommended CM Extreme series here..?
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/126427-urgent-plz-help-me-buy-power-supply-cabinet.html
Thread URGENT : plz help me buy a power supply and a cabinet - Page 3 - Digit Technology Discussion Forum - Tech Discussion Forums in India | Digit Forum | BoardReader This thread Refback 14-06-2011 04:23 PM
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5533 Today 12:49 PM
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
How to get motherboard to power up flamore_54 Chit-Chat 0 25-04-2010 06:19 PM
Corsair Psu Query!! BULLZI Hardware Q&A 25 06-10-2008 10:05 AM
Cases: How to Avoid Overheating Gigacore Tutorials 3 20-04-2007 01:33 PM
- by c4u
