Old 03-05-2010, 05:12 PM   #1 (permalink)
Post Gaming rig for rs60000
I want to buy an gaming PC for rs60000. Can anyone suggest the best configuration that can play all the upcoming games.
Thanks.
123shree is offline
Old 03-05-2010, 05:34 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: Gaming rig for rs60000
AMD Phenom II X6 Processor [ Model 1055 ] {tooooo much future proof}
M4A89GTD PRO or Biostar TA 890GXE
KIngston 2x2 gb ddr3 @5.4k or Corsair CMX4GX3M2A1600C9 4gb kit
NZXT M59
Corsair CMPSU-650TX or FSP Everest 80Plus 600 Watts or
Logitech Cordless Desktop EX90- Black
Acer 23" H235H LCD Monitor
WDC 500GB Black S-ATA 3.5" Hard Drive - WD5001AALS {may be X2}
Sapphire HD5870 1GB GDDR5 PCIE or Sapphire HD5850 1GB GDDR5 PCIE (Game Edition)
APC Back - UPS BE 650Y-IN
saurabh_1e is offline
Old 03-05-2010, 05:40 PM   #3 (permalink)
dude nice configuration. But I had clearly mentioned gaming PC for 60000. your configuration costs about 80000rs.
123shree is offline
Old 03-05-2010, 06:48 PM   #4 (permalink)
teh tech saviour!
saurabh_1e's Avatar
AMD Phenom II X6 Processor [ Model 1055 ]@10.5k
Biostar TA 890GXE@6.5k or wait for an 870 chipset
FSP Everest 80Plus 600 Watts@5.5k
WDC 500GB Black S-ATA 3.5"@3.2k
Sapphire HD5770 1GB GDDR-5 @11k
Acer 20" V203H LCD Monitor@7k
APC Back - UPS BE 650Y-IN@3.3k
NZXT M59@4.2k
Coolermaster Hyper N520@2.5k
Logitech G1 Gaming Desktop@1.5k
Old 03-05-2010, 10:42 PM   #5 (permalink)
PhotonAttack
DigitalDude's Avatar
6 cores is an overkill for the gaming PC. it will just draw more power and give more heat.
what games you intend to play, what will be your general usage and what other components/stuff you already have (like UPS, keyboard etc) so that we can refine more.
i3-530 - 5.7k
CM Hyper 212 CPU cooler and CM Freeze Thermal compound - 2k
Gigabyte GA-P55-USB3 - 8.2k
NZXT Gamma - 2.3k
Corsair VX550 - 5k
G.Skill Ripjaws 2X2GB kit DDR3 1333Mhz - 7.5k
Sapphire HD5850 1GB GDDR5 - 16k
WDC Caviar Black 500GB - 3.2k
APC UPS - 3.3k
10k remaining balance it between Display, mouse and keyboard. as they are highly based on personal preferences.
if you don't want a HD5850,
get the HD5770 - 9.7k
Cooler Master CM690 II Plus Case - 5k
DELL 21.5" ST2210 Full HD (HDMI, DVI-D) - 9.3k
and spend the 4.5k on keyboard and mouse.
or an Core i5-750 Quadcore CPU - 10k
and sorry I'm not familiar with AMD proccy, mobos
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is online now
Old 03-05-2010, 10:51 PM   #6 (permalink)
teh tech saviour!
saurabh_1e's Avatar
core i3 and i5 will be obselete soon .no upgradation will be possible
and for around 1k more than core i 5 you are getting 6 cores and in future application and games will utilize 6 cores.
Go with amd this is much more future proof and powerful
Old 03-05-2010, 11:31 PM   #7 (permalink)
your first part right. i3 & i5 will die as the Socket LGA1156 will no longer be needed. Sandy Bridges will use LGA1355 socket.
however, hardly any present game utilize 3 cores well. forget 4 cores & u talking about 6 cores? 6cores not good for anything except heavily threaded work like encoding. OP best with either 2 cores (Phenom II X2) or Phenom II X4. 6 cores over kill & unnecessary for his requirements.
Sam is online now
Old 04-05-2010, 11:17 AM   #8 (permalink)
i3-530 - 5.7k
NZXT Gamma - 2.3k
Corsair VX550 - 5k
APC UPS - 3.3k
_
I have a standard keyboard, an optical mouse,an old samasung speaker, an old samsung moniter.
123shree is offline
Old 04-05-2010, 11:36 AM   #9 (permalink)
A little ego goes nowhere
Proc - AMD Athlon II X4 /Phenom II X4 ~ 5k
Mobo - MSI /Gigabyte 880GM ~ 8.5K
RAM - 4GB (2*2)1333Mhz DDR3 G.SKILL Ripjaws / Corsair XMS3 ~ 7.2K
HDD - 1TB Seagate Barracuda / WD Black ~ 4.2k
GFX - Sapphire ATI Radeon HD5770 1GB ~ 10K
PSU - Corsair VX550 ~ 5K
Cabinet - NZXT Gamma ~ 2.2k
ODD - L.G./Samsung DVD-Writer ~1.1K
UPS - APC RS 800VA ~ 5K
Display - Benq G2220HD ~ 7.5K
Input - Logitech MX 518 mouse ~ 1.8.K
abhijitsb306 is offline
Old 04-05-2010, 05:44 PM   #10 (permalink)
teh tech saviour!
saurabh_1e's Avatar
lets ask shree what he wants
will there be only gaming or some heavily threaded work like encoding will also be there
putting 60k and getting just two cores ( i don't think so; may be go with upcoming 960t or phenomx4 965)
Old 04-05-2010, 06:28 PM   #11 (permalink)
main purpose is for gaming. but I may do some encoding(rarely).
123shree is offline
Old 04-05-2010, 11:51 PM   #12 (permalink)
2 cores, a bit too less. 4 cores good. do get a cooler. get the X6 only if u want Over Clock. 2.8Ghz X6, is value but is best damn value once u OC.
Sam is online now
Old 05-05-2010, 09:42 AM   #13 (permalink)
Wise Old Ghoul
Piyush's Avatar
dude just buy hd 5850 with corsair vx 550
phenom II x4 940/945 will be enough for u(dont go for 955BE ,its got some heating issues)
mobo:880 based
rest of all depends on u and ur budget
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 09-05-2010, 12:27 AM   #14 (permalink)
Techie By Heart
mavihs's Avatar
_
i had the opportunity to test the AMD 1090T before its release & its way cooler then the other proccys even when O/Ced.
Also its better to for that then AMD 965 as its got turbo core!
http://yfrog.com/jy44thubanj
+1
havn't heard anything of that sort....though AMD 965BE though give more heat coz of higher volt & TDP!
█§ ║╖ î v â ╥╥╖█(™©)
mavihs is offline
Old 25-05-2010, 05:54 PM   #15 (permalink)
keen to learn..
hye bro . I do asp.net programming and love to play heavy games like GTA 4, COD5,Mafia 2 etc. am bit confused b/w desktop and laptop as i hv sold my PC.
i know the condition of a PC after 1 yr but i dnt know anything abt d lappy.
so plz u tell me that should i go for lappy or PC. i want intel i5 .
a2mn2002 is offline
Old 26-05-2010, 10:16 AM   #16 (permalink)
Post Re: Gaming rig for rs60000
If you want to play games you should buy a desktop coz laptops are not at all suited for gaming.
Processor - Intel core i5 750
Motherboard - Gigabyte H55M-USB3
RAM - Corsair 4GB DDR3 1600MHz C9 Titanium
HDD - Segate Baracuda 7200.12- 1TB
Graphics card - Saphire Radeon HD 5770
Optical drive - LG GH22 SATA 22x DVD-writer
Power supply - Corsair 550VX
Cabinet - Cooler Master Centurion 690
Monitor - Acer V233H 23.6" FULL HD LCD Monitor
Keyboard - Microsoft comfort curve 2000
Mouse - Razer salmosa
Speakers - Creative Inspire M2600
Laptops need a lot of maintenance and should be careful while carrying it around. but if you want to buy a laptop go for the Asus N61Jv. It has a pretty decent configuration like USB3, Core i3, GT 325M graphics, nvidia Optimus, etc.,
123shree is offline
Old 26-05-2010, 06:41 PM   #17 (permalink)
bORn To RIse....
rahul.007's Avatar
nice config....
dont let ALEINWARE hear this....
phenom II 955 B.E 3.2 ghz(its hot) no more:mrgreen:|coolermaster hyper 212 evo:cool: | msi 790gx-g65|msi radeon hd6770:hyper: |corsair 2*2gb + kingston 2gb 1333mhz ddr3|seagate 500gb sata X 2, 1tb X 1|lg dvd|seasonic s12ii 520w:punch: |cooler master elite 310|cooler master 120 mm fans X 2|benq g2220 HD|logitech keyboard+mouse|Creative SBS A100|apc 550va|kodak c913|motorola fireXT:wink:
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
rahul.007 is offline
Old 26-05-2010, 07:46 PM   #18 (permalink)
Techie By Heart
mavihs's Avatar
go for desktop if you want to game!
i want intel i5
any specific reason you want to go for that?
Can you fill the below questionnaire so i can suggest you a good config!
1. What is your MAX budget?
2. Are you open to alternate ideas/products giving similar better performance but offering more VFM/ sellers? If not- why?
3. What is the purpose of the computer? (Note: If you are planning to say multimedia, you will have to be more specific as all types of systems are capable of doing that)
4. Planning to overclock?
7. What resolution will the screen run at?
mavihs is offline
Help building a gaming rig vicky2008 Hardware Q&A 10 15-04-2010 12:23 AM
help needed to build gaming rig under 24k prakum Hardware Q&A 4 07-04-2010 05:11 AM
Need Help in building my new Gaming Rig Sid_gamer Hardware Q&A 84 18-03-2010 05:08 PM
Need a gaming RIG in 55k cool.vicky Hardware Q&A 5 12-02-2010 02:00 PM
need a gaming rig under 14k suspect07 Hardware Q&A 2 06-02-2010 05:21 PM
- by c4u
