Old 02-05-2010, 10:26 AM   #1 (permalink)
Default amd athlonx4 compatiblity with PC 10666?
Is a DDR 1333 Mhz (PC 10666)4gb dual kit ram going to be compatible with an AMD athlonx4 630 propus??
The reason i`m asking this is because AMDs offcial page for athlon x2 says that DDR3 1333Mhz(it only says PC 10600) is compatible with those processors.Here is the link:
http://www.amd.com/us/products/deskt...omparison.aspx
the ram i was lookin to buy is the m mushkin silverline series one:
http://www.primeabgb.com/index.php?p...mart&Itemid=53
also one more thing...what exactly is dual channel...if i buy 2GB now and 2Gb ram later...can i configure them for dual channel operation?
"..believe in me and you shall die forever.."
iceVamp is offline
Old 02-05-2010, 11:05 AM   #2 (permalink)
BE FREE
Default Re: amd athlonx4 compatiblity with PC 10666?
yep its compatible, why don't you go for corsair xms 4gb kit.........
dual channel means ram kits in 2 slots........ yes you can add another 2 gb kit after wards and it automatically becomes dual channel........
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 02-05-2010, 11:25 AM   #3 (permalink)
yeah i`d like to go with the xms one too...but its too costly...any idea if i can get it online for less than 6.5k?
iceVamp is offline
Old 02-05-2010, 11:31 AM   #4 (permalink)
BE FREE
just another 6-7 hundred bucks more than the one you selected, other wise you could go with your selection.......only thing not famous here and might be very few users , so hard to comment..........
Old 02-05-2010, 04:51 PM   #5 (permalink)
laborare est orare
Cilus's Avatar
For having a dual channel configuration, both rams have to be of same size and same speed. If you buy a 1333 MHz 2 GB ram now, u have to buy a 1333 MHz, 2 GB ram to use them in dual channel configuration.
Right now I'm using two ram of 1333 Mhz, one from Transcend and other from Kingston.
Cilus is online now
Old 02-05-2010, 06:16 PM   #6 (permalink)
BE FREE
not necessary, even if the rams are of different clock speeds it would run dual channel, however at the lowest of both........
AMD announced 6-Core Processor for Desktops celldweller1591 Technology News 6 03-05-2010 11:06 AM
AMD Launches 6 Core CPU-ready 890GX Chipset Mobo topgear Technology News 7 06-03-2010 05:55 AM
AMD to be taken over by Nvidia????? Abheek Technology News 42 02-03-2008 09:18 PM
It's time for AMD to give it up Indyan Technology News 21 19-12-2007 05:50 PM
AMD Athlon™ 64 X2 Dual-Core arrives !!! mohit CPU / Motherboards 2 31-05-2005 12:54 PM
- by c4u
