Originally Posted by coolest111
My usage is basically fulfilled by dell xps 13 but i want 2 try mac....
Is it worth investing 15k more for macbook pro?
Wil i b able 2 run win7 like in dell xps 13 on macbook pro?
Every suggestion counts thank u 4 ur advice
You can definitely run Windows 7 through bootcamp in MacBook Pro.
Now about your question, it's upto you to choose an OS. You can basically do all the necessary jobs across both OS and a similar set of software are available to both of the platforms. If you're satisfied with Windows 7 and want to save some bucks, go for Dell. On the other hand, if you're attracted to Mac OS X for whatever reasons, you can go for it, provided you can spend that amount of cash. MacBook Pros are superbly built machines and usually serves the users for a long period.
