Old 01-05-2010, 10:42 PM   #1 (permalink)
Default New PC help
Hey
I am planning to buy a new pc.
I am in 3d animation. So please suggest me what will be good hardware in this field.
My configuration :-
Processor : AMD Phenom II x6 1090T or AMD Phenom II x6 1055T
Motherboard : ASUS M4A89TD Pro or MSI 890FXA GD70
Ram : Corsair Dominator DDR3 1600MHz 2x3GB
Graphic Card : ATI RADEON HD 5750 or Sapphire Radeon HD 4850
Hard Disk : Seagate 1TB 7200
Power Supply : Corsair TX 850
Cabinet : CoolerMaster 690
This is what I have been searching, So I want your suggestions too plus can anyone give the price of above configuration..
My maximum budget is 60K
devcga is offline
Old 01-05-2010, 11:00 PM   #2 (permalink)
Default Re: New PC help
Originally Posted by devcga View Post
Hey
My configuration :-
nice. really nice 1.
Processor : AMD Phenom II x6 1090T or AMD Phenom II x6 1055T ---> stick to 1st option.
Motherboard : ASUS M4A89TD Pro or MSI 890FXA GD70 ---> too much. get something like 890GX or 870X(to be launched soon). or even 7series wil be good.
Ram : Corsair Dominator DDR3 1600MHz 2x3GB --->2X2Gb enough
Graphic Card : ATI RADEON HD 5750 or Sapphire Radeon HD 4850 --->HD5770
Power Supply : Corsair TX 850 ---> Corsair TX550W is all u need.
Cabinet : CoolerMaster 690 -->NZXT M59 if u want little style.
Sam is online now
Old 01-05-2010, 11:15 PM   #3 (permalink)
thanks for reply sam
can you please tell me the prices of above configuration
devcga is offline
Old 01-05-2010, 11:22 PM   #4 (permalink)
my pleasure buddy. ok heres goes the prices: (approximate)
Processor : AMD Phenom II x6 1090T:16k AMD Phenom II x6 1055T:11k
Motherboard : say MSI 785GM E53: 5.5k
Ram : Corsair Dominator DDR3 1600MHz 2x2GB: ~7k
Transcend 2X2Gb value ram @ 1333Mhz: ~5.6k
Graphic Card : Sapphire Radeon HD5770: 9k+
Hard Disk : Seagate 1TB 7200: ~4k
Power Supply : Corsair TX550W: 4.8k
Cabinet : NZXT M59: 3.8k
total: 39.7k = ~40k. so still 20k left
Sam is online now
Old 02-05-2010, 01:00 AM   #5 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: New PC help
Sam.Shab buddy you got it wrong. The 1090t is 16k while 1055t is 11k.
@ devcga
Buddy go for radeon 5850 instead of 5770 and with remaining cash, invest in a good 22 or 24 inch lcd monitor.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 02-05-2010, 01:59 AM   #6 (permalink)
damn. i messed up the pricing. thanks for pointing out. new to this naming scheme, so not able recognize the mistake.
Sam is online now
Old 02-05-2010, 03:49 AM   #7 (permalink)
thanks everyone
devcga is offline
Old 02-05-2010, 06:07 AM   #8 (permalink)
pulsar_swift's Avatar
Sam bhai, you sure that the hexacore will wore on 785GM E53, BIOS update is already available ?
pulsar_swift is offline
Old 02-05-2010, 07:10 AM   #9 (permalink)
I too think that would be a problem, coz I want mah pc to take out good renders(3d), so I think motherboard should be equivalent to processor
devcga is offline
Old 02-05-2010, 08:03 AM   #10 (permalink)
BE FREE
it would work - however better go with 890 chipset.........
do you game?
if not go for pro card.........
dominator ram would cost more than that, better go with xms.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 02-05-2010, 08:35 AM   #11 (permalink)
do you game?
Yea I game too...but its not necessary
and wot pro card should I go for and what is the difference between dominator and xms and please tell the pricing too
devcga is offline
Old 02-05-2010, 10:57 AM   #12 (permalink)
BE FREE
Corsair CMD4GX3M2B1600C8 4GB Kit-Rs :10763/-
Corsair CMG4GX3M2B1600C7 4GB Kit-Rs :15888/-
these are dominator kits of 4gb and are high performance at low latency rams.
xms are like value rams priced considerably-
Corsair CMX4GX3M2A1600C9-Rs :7688/- -4gb kit
Corsir TR3X6G1600C9 6GBKit -Rs :10763/-
these prices are without tax add 4%,
and for pro card what is your max budget? and you wont be able to play games on it, and they would very costly, so as per your budget, selection could be made.
Old 02-05-2010, 05:21 PM   #13 (permalink)
laborare est orare
Cilus's Avatar
I have few suggestions to make:
1st of all, the kind of applications mentioned by devcga, does not need very low latency or high performance ram. They are mainly good for gaming. Here the amount of ram present will matter more in performance.
So my suggestion is opt for 2X3 GB value ram. Right now Kingston 2 GB 1333 MHz models are available at 2.65k (I got one last week).
So 6 GB will be 7.95k.
2ndly: My choice of Graphics card is little different. It is Zotac GTX470 1280MB GDDR5 @ 22k
Reason is in 3D applications GPU computing is getting mainstream now, Now ATI Stream and Nvidia CUDA both are on the field and both will offer high performance. But CUDA is much more mature than ATI Stream and the support for CUDA by different software is greater than ATI stream stream. Also Nvidia Fermi is better than ATI 5 series in card in Direct-computing and other CPU related tasks as reviewed in Guru3d.
3rdly For Power Supply go for Cooler Master GX-650W @ 5.5k
And Finally: Go for AMD 890 based chipset mobo. The price difference between 785 or 790 Chipset based mobo and 890 based mobo is very less and Phenom II X6 is designed for thus particular chip-set. So a performance boost will be there.
Biostar TA890GXE @ 6.6k will be good choice.
Cilus is online now
Old 02-05-2010, 05:27 PM   #14 (permalink)
Super Moderator
asingh's Avatar
You know about the temperature issues with the Fermi. Unless not in A/C environment, those are ill-suited for India.
asingh is online now
Old 02-05-2010, 11:00 PM   #15 (permalink)
Well I don't have A/C...so please suggest me good budget graphic card
devcga is offline
Old 04-05-2010, 10:35 AM   #16 (permalink)
A little ego goes nowhere
For 3D animation you can check out the ATI Firepro 3D workstation series or nvidia quadro FX /NVS series
ATI Firepro V3750 ~ 8K
ATI Firepro V3700 ~ 6K
abhijitsb306 is offline
Old 04-05-2010, 03:19 PM   #17 (permalink)
is this good?
devcga is offline
- by c4u
