Dear all
I am planing to overclock my proc and IGP of my desktop which i bought around 6 weeks back. My pc config is as follows.
AMD A II X4 630
ASUS M4A785TD-V EVO
CM ELITE 310 --> planning to add 2 fans next weekend
FSP SAGA II 400W
WD BLUE 500GB
TRANSEND 2GB DDR3 --> planing 2 buy 2GB next weekend
HP DVD
APC 550V
ALTEC LANSING BXR1221
DELL ST2210 --> planing to buy next weekend
STOCK HSF
I want to overclock both IGP(HD4200) and my PROC at stock voltage and stock HSF but I am planing to mount 2 extra 120mm fans to my cm elite 310 (one default 120mm fan is already mounted at back panel).
In CM elite 310 i have 3 places left to mount fans( 2 at side panel and 1 at front panel). Now my question is if i buy 2 new fans, for better overclocking where should i mount them and in which mode (exhaust or intake). And also can some one suggest me some descent fans.
Now coming to the over-clock part , I want to do it in bios by changing FSB only , I dont want to set/increase other settings like ram or voltage or NB etc ( ryt now everything is set to auto).
I have never overclocked my system before and this is a new PC, thats why i want some one to suggest a novice procedure which will get me decent overclock and wont harm my PC
Regards
