01-05-2010, 03:06 PM
Monitor quest
CAN WE START A NEW THREAD ON MONITOR ONLY ?
1) mention your monitor with COMPANY name and MODEL no,
2)date purchased and by how much
3)supported by which mobo and/or graphics card
4)PROBLEMS found
5)any special features of your monitor.
6) any tweaks you have done to it
7) any mod you have done to it.
and last but not least at all: any question regarding monitor.
(SEEING IS BELIEVING)
I WOULD LIKE TO POST MY FIRST QNS:
Does amd 790 GX MOBO without any graphics card support 22" monitor of any make?
01-05-2010, 03:11 PM
BE FREE
Re: Monitor quest
^ if you dont have video card inbuilt then, its a must you use a discreet card, otherwise how would you get output- question of screen size doesn't arise.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
01-05-2010, 04:04 PM
Re: Monitor quest
It is a board from ASUS namely M4A78T-E. Specifications:
now suggest
01-05-2010, 08:28 PM
BE FREE
Re: Monitor quest
yep you can use 22" monitor.
01-05-2010, 09:30 PM
Re: Monitor quest
except for gaming.
02-05-2010, 07:49 AM
BE FREE
Re: Monitor quest
Originally Posted by Sam.Shab
except for gaming.
yep you 100% right, as his question was - whether it could be used or not? so I answered in that context only, - as I've run 24" monitor on intel 915g igp.
02-05-2010, 12:16 PM
Wise Old Ghoul
Re: Monitor quest
^^Benq 22 hd lcd is available under 10k?
is it good compared to other brands?
suggest a few more under 10 k with 22"screen and good resolution also
02-05-2010, 12:22 PM
bORn To RIse....
Re: Monitor quest
me using benq g2220 hd lcd.... superb monitor.... hd playback is also very good.... it has only 1 con - no hdmi port(it has dvi and vga).... but it is available under 8k(7.6k).... you should also look at benq e2220 hd lcd.... same monitor but with hdmi port.... price is 8.5k....
courtesy:- nehru place
DO WHAT YOU THINK, BUT THINK BEFORE YOU DO.. :)
02-05-2010, 12:32 PM
Wise Old Ghoul
Re: Monitor quest
^^thanks
but any other recommendations ?
or any tips buying a new one?
and whats the max res of urs?
02-05-2010, 12:41 PM
bORn To RIse....
Re: Monitor quest
max resolution:- 1920*1080(full hd)....
buy a new monitor according to the graphics power that you are buying....
02-05-2010, 12:44 PM
Wise Old Ghoul
Re: Monitor quest
thanks
consider hd 5770
now whats ur suggestions?
03-05-2010, 11:20 AM
Re: Monitor quest
except for gaming.
That means for gaming i need to buy a discreet GRAPHICS CARD & more the honey more the sweeter. So what is the benefit of having a mobo with onboard graphics? I mean what this IGP is basically for?
AOC 2236 VW
DELL ST2210
03-05-2010, 05:45 PM
Re: Monitor quest
IGP gaming is limited to 1024X768 or the next resolution. within these resolution u will get playable FPS with mid settings or full settings.
at FULL HD, most games will either crash or will give u FPS. now think playing NFS Shift in SlideShow mode, forget Crysis. it'll b long ago crash the system. its similar trying to run Crysis on a 19" powered by G31 with everything set to high.
03-05-2010, 09:19 PM
Re: Monitor quest
Understood
not understood. FULL HD MEANS WHAT?
Plain & simple I can buy a 22" monitor plug it and can watch MOVIE, do normal office work in MSOFFICE, BROWSE INTERNET,play STRATEGY GAME.
BUT whenever FPS games will come into consideratiion i need to buy a graphics card. is that so?
03-05-2010, 09:46 PM
Super Moderator
Re: Monitor quest
Full HD is a resolution standard which starts with 1080p. That is 1080 lines of resolution, which are progressively scanned, not interlaced. This is the minimal. So if you have a monitor with 1920x1080p, it is 1920 horizontal lines x 1080 vertical lines. Imagine 1920 slices lined up, and subsequently stacked 1080 times, to give the full resolution. The composite of the above gives the amount of pixels on a screen, and FPS is the frames being rendered. So a GPU is doing a whooping 1920x1080x60 pixel render within one second if the FPS = 60. Wow that is a lot.
Now the above you mentioned, movie, ms office, browsing all fall in the realm of 2D. So it can be rendered without a GPU. But for 3D (games) a discrete VGA is required, since the computations and render speed is so high. Hope this makes sense.
03-05-2010, 10:12 PM
Re: Monitor quest
understood clearly. thanks.
means onboard graphics is enough with a 22" MONITOR.
That's it. Here comes the qn of a separate graphics card like ATI OR NVIDIA. GOT IT. AND almost all the games today fall under that 3D arena.
one more qn: The Microsoft game AOE which is a strategy game falls under 3D? I DO NOT THINK SO coz i can play it without any problem now.
03-05-2010, 10:18 PM
BE FREE
Re: Monitor quest
^ you can play low end , less power hungry games, also 3d on igp which has chipset like 4200, at low res, however games like crysis, codmw2, etc, to name a few, you need a definite discreet card, and if the card belongs to high end categories of both manufactures, then you can play at high resolutions on 24" or 30" lcds.
04-05-2010, 12:57 AM
Re: Monitor quest
guyzz... plz tell me the exact review of samsung-P2350 as i m planning to buy it.
if possible plz post the current price of this monitor.
according to one person who is having this monitor posted a comment on
http://www.tomshardware.co.uk/forum/...ng-p2350-p2370
which is (I bought the P2350 from Sam's Club in January becuase the price seemed too good to be true - besides, I had used 17" and 20" Samsung monitors in the past. Now, I can tell you there IS a reason for the cheap price and a reason no one else sells these monitors. My screen turned pinkish after three weeks. The color cast could not be adjusted out so I returned the defective monitor to Sam's. Because of my past experience with Samsung, I did a swap-out for another P2350. The new one started turning itself off after one week. At first it happened once every two days . . . then the problem increased to once an hour. So I returned the second monitor for a refund. After experiencing two defects in a row, I have a better understanding of why Sam's is the only retailer with these and why they are so cheap. Oh, by the way, I am forgetting about that new Samsung 55" LED TV I was thinking about.)
so kindly give ur valuable suggestion so that i can take my decision.
Evil Lives 4ever......
05-05-2010, 03:28 PM
#19 (permalink)
Re: Monitor quest
Ok guys now tell me which 22" monitor to buy that will include
1) vga, dvi & hdmi port?
2)under 10 k.
3) with respective port cables included.
viewsonic needs no mention.
My preference is DELL ST2210.
05-05-2010, 03:36 PM
#20 (permalink)
bORn To RIse....
Re: Monitor quest
nice monitor....
you may also look for BENQ E2220 HD lcd.... its has all the things that you want and would priced around 8.5k(probably lesser then that as i saw this price 3 weeks before)....
05-05-2010, 04:27 PM
#21 (permalink)
Re: Monitor quest
Originally Posted by rahul.007
nice monitor....
You may also look for benq e2220 hd lcd.... Its has all the things that you want and would priced around 8.5k(probably lesser then that as i saw this price 3 weeks before)....
can you give a comparison chart of the two?
06-05-2010, 03:42 PM
#22 (permalink)
bORn To RIse....
Re: Monitor quest
06-05-2010, 08:50 PM
#23 (permalink)
Re: Monitor quest
THANKS .
Tell me one thing, except contacting DELL INDIA and getting things from them is there any shop in kolkata who sells DELL MONITOR having a good stock?
One more thing i have changed my mind to buy DELL SX2210 not ST2210.
07-05-2010, 09:58 PM
#24 (permalink)
Re: Monitor quest
No one to fetch me?
08-05-2010, 04:42 PM
#25 (permalink)
bORn To RIse....
Re: Monitor quest
no idea about kolkata.... but dell sx2210 is surely good....
10-05-2010, 05:14 PM
#26 (permalink)
Re: Monitor quest
YES I KNOW. it has all WHAT I AM LOOKING FOR :
1) vga, dvi(HDCP) & hdmi port with at least a DVI cable INCLUDED
2)under 14 k.
3) should be 22"
4) max resolution 1920x1080
5)not above 2ms response time.
10-05-2010, 08:49 PM
#27 (permalink)
Re: Monitor quest
2)under 14 k.
3) should be 22"
does Benq monitor comes with the necessary cables? i heard E2200 doesn't include the HDMI cable.
rahul, u own the Benq G2220. u got the DVI cable or payed extra for it?
10-05-2010, 09:05 PM
#28 (permalink)
bORn To RIse....
Re: Monitor quest
i got a dvi and dsub cable....
11-05-2010, 12:21 PM
#29 (permalink)
Re: Monitor quest
it does not come i think. reviews do not tell of that.
not clear
got = bought OR got = boxpack .
11-05-2010, 12:43 PM
#30 (permalink)
bORn To RIse....
Re: Monitor quest
i got it in the boxpack....
