Old 30-04-2010, 05:19 PM   #1 (permalink)
Default Need help buying 700 $ PC (Rs ~30,000)
My friend needs a PC for under 700 dollars. (Rs ~30,000)
I thought of getting him this setup :
How is this motherboard?
http://www.newegg.com/Product/Produc...82E16813131595
EDIT : He decided on going for a Radeon 4670 512 MB. We both agreed that the rig can be upgraded at a later time (upgrade of graphic card) and that it should be enough for the time being.
falling is offline
Old 01-05-2010, 07:38 PM   #2 (permalink)
teh tech saviour!
saurabh_1e's Avatar
Default Re: Need help buying 700 $ PC (Rs ~30,000)
First of all what is your location.
Then only we can help.
and if you are living in india then building pc on newegg is not of any use
saurabh_1e is offline
Old 01-05-2010, 10:06 PM   #3 (permalink)
Kerala, Trivandrum. I used newegg for reference.
falling is offline
Old 01-05-2010, 10:25 PM   #4 (permalink)
Alive Again...
satyamy's Avatar
better use theitwares.com
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 01-05-2010, 11:04 PM   #5 (permalink)
better post in: Hardware Q&A. will get more & better replies.
Sam is online now
Buying a Digital Camera jackal_79 Cameras and camcorders 14 22-04-2010 05:47 PM
Is Nokia N900 worth Buying ? augustya Buying Advice 4 06-04-2010 12:23 PM
Help in buying Wireless router !!!!!! 047 Hardware Q&A 2 30-03-2010 05:51 PM
buying phone from infibeam.com ankitsagwekar Buying Advice 1 22-03-2010 02:36 PM
Buying a new PC... need suggestions! rahul941400 Hardware Q&A 24 18-02-2010 04:21 PM
- by c4u
