Old 29-04-2010, 12:24 AM   #1 (permalink)
Default A laptop within around 45k!
hey guys,
i want a laptop within Rs. 45K.
Preferences would be a 17inch screen!
else all should be pretty much ok and Dell or sony!
pls suggest...
thanks in advance
magneticme200
---------- Post added 29-04-2010 at 12:24 AM ---------- Previous post was 28-04-2010 at 10:51 PM ----------
pls help me choose guys.!
magneticme200 is offline
Old 29-04-2010, 02:25 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: A laptop within around 45k!
A lappy with a 17" screen size and tat too in 45K budget is NOT possible.. looks like u are probably looking for a gaming lappy or for movies (considering ur requirement of a bigger screen size)
in the range of 45-50K, u will get 15.6" (in SONY VAIO E Series at 50K, perfect for gaming, entertainment, movies and also work related apps) or 16" lappy from DELL..
if u can tell me ur requirement, i can help u in a better way..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 29-04-2010, 09:04 PM   #3 (permalink)
laborare est orare
Cilus's Avatar
At this budget Acer 5740g-6979 @ 43k is the best buy. Its raw performance is unmatched by any other laptops from other brands even in 50k range. Also coupled with a great battery life (3 Hrs for normal use), light weight (2.78 Kg) and all the necessary features, it is a must have option. Check its review in Anandtech whereit was selected as the best gaming laptop in budget.
My roommate owns this one, actually purchased after my suggestion and I tested it personally.
battery life for gaming is 1.6 Hrs (approx). I tested it with Crisis with all the setting high and 4X antialising. Yet it was giving frame-rate over 30 all the times. For watching movies, battery life is around 2.1 Hrs(approx).
Here goes the config:
Operating System Windows 7 Home Premium 64-bit CPU Type Intel Core i5-430M(2.26GHz) with 2.57 Ghz Turbo Boost
Screen 15.6" (max Res: 1366 X 768)
Memory Size 4GB DDR3 (1066 MHz)
Hard Disk 500GB 5400 rpm SATA
Optical Drive DVD Super Multi Graphics Card ATI Mobility Radeon HD 5650 1 GB GDDR3 DirectX 11
Audio
Card Reader:
True 5.1 Channel Surround Sound Output
3rd Generation Dolby Home Theater Audio Enhancement, featuring Dolby Digital Live, Dolby Pro Logic IIx, Dolby Headphone, Dolby Natural Bass, Dolby Sound Space Expander, Dolby Audio Optimization, Dolby High Frequency Enhancer Technologies
High Definition Audio Support
Built-in Microphone
5 in One Card Reader
Communication Modem, Gigabit LAN and WLAN(b/g/n) Battery Life 3.0 hours Dimensions 15.10" x 9.90" x 1.03" - 1.50" Weight 6.16 lbs.
Cilus is online now
acer laptop and big trouble , urgent help needed fun2sh Laptops and Netbooks 6 19-04-2010 08:10 PM
Laptop Cooling Pad-Help this out joey_182 Hardware Q&A 6 24-03-2010 11:53 AM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
How to play movies/project screen from laptop to TV ??? sohin Hardware Q&A 0 14-02-2010 11:44 PM
Acer Aspire 4720 Z Laptop Review FilledVoid Reviews 8 11-01-2008 05:06 PM
- by c4u
