Old 28-04-2010, 08:38 AM   #1 (permalink)
throttle press fire !!
Talking Internal TV Tuner Card
Guys i just have 2-4 hrs left.... before I buy my new Dektop
I just decided to BUY an INTERNAL TV TUNER CARD for my RIG . Its a high END rig, costing me around 90,000 without TV tuner card. So, pls tell me the Best TV tuner card within Rs10000 and also one within Rs 6000. Thank You
altecmayank is offline
Old 28-04-2010, 11:03 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: Internal TV Tuner Card
oh man, 90k rig!! whats the config..?
go for usb tv tuner card ,that will be portable also. and i think pinncale will be the best (dono the model). at u r rate u can get HDTV capable card.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Need Suggestion on TV Tuner Card emmarbee Hardware Q&A 6 20-11-2009 06:59 AM
Cheap internal Tv tuner card eureca_eureca Hardware Q&A 2 03-06-2008 07:37 PM
Toshiba Laptops Pricelist - January 2008 anuvb101 Hardware Q&A 1 23-01-2008 06:22 PM
VIA UniChrome Pro Display Driver ver 0.8 gary4gar Open Source 19 22-12-2007 02:09 PM
Connecting a TV Tuner Card... !! grinning_devil Hardware Q&A 21 22-02-2006 11:41 PM
- by c4u
