Old 26-04-2010, 11:28 PM   #1 (permalink)
rohit2hell's Avatar
Default Wanna buy a Laptop 40-45K
hi to all Digitians..
I am an animation student..
works prefrbly in Flash - 3dsMax - Maya - AfterFX - Photoshop
I already hv a Desktop
bt i wanna buy a Laptop too ..
My budget is 40-45K .. suggest me a nice rig..
so that i can depend on it .. whr ever i hv to go...
Thank In Advance :C_smile::C_smile:
rohit2hell is offline
Old 27-04-2010, 01:31 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Wanna buy a Laptop 40-45K
At this budget the best option is Acer 5740G-6979. It offers not only the best configuration but also one of the best battery life compared to the laptops from other brand in the same range.
Specification
Operating System Windows 7 Home Premium 64-bit
CPU Type Intel Core i5-430M(2.26GHz) 2.53 GHz turbo Boost
Screen 15.6"
Memory Size 4GB 1066 MHz DDR3 (upto 8 GB support)
Hard Disk 500GB 5400 rpm SATA
Optical Drive DVD Super Multi
Graphics Card ATI Mobility Radeon HD 5650 1 GB GDDR3 DirectX11
Video Memory 1GB DDR3 VRAM
Communication Modem, Gigabit LAN and WLAN
Battery Life 3.0 hours
Dimensions 15.10" x 9.90" x 1.03" - 1.50"
Weight 6.16 lbs
Display: 15.6" 1366X768 with LED back light & Acer Technology
Audio: True 5.1 Channel Surround Sound Output
3rd Generation Dolby Home Theater Audio Enhancement, featuring Dolby Digital Live, Dolby Pro Logic IIx, Dolby Headphone, Dolby Natural Bass, Dolby Sound Space Expander, Dolby Audio Optimization, Dolby High Frequency Enhancer Technologies
High Definition Audio Support
Built-in Microphone
This is the best performance laptop in this budget. If you go for Sony or dell, you will get Core i3 and HD 5470/5450 graphics card which are just good for watching movies. don't event think of playing new games on it. AnandTEch also reviewed it and said it is one of the top products.
Cilus is online now
Need help to buy a new laptop neerajvohra Hardware Q&A 10 11-06-2010 11:54 PM
3.5" SATA HDD powerd by Laptop k_mridul Hardware Q&A 0 28-02-2010 04:21 PM
Wanna buy a Laptop Cerebral Assasin Reviews 4 09-12-2007 10:37 PM
wanna to buy a laptop thecreativeboy Laptops and Netbooks 4 08-09-2007 11:25 PM
- by c4u
