Re: Which is best motherboard for AMD athlon 2 X4 630/phenom X2 550(socket AM3 type)
Originally Posted by amit.n
Hi guys,
I m confused which will be best suited motherboard for athlon 2 X4 630/phenom X2 550(socket AM3 type).
I was planning to take Gigabyte GA-MA78GM-US2h.
Though it supports AM3 recently.
but on gigabyte site it is made specially for AM2+.
Is there best Supported and same priced Motherboard for AM3 above mentioned processor?
Similarly which 2*2GB RAM best supported for this processor.
it is AM2+/AM3 mobo.
its AM2+ cause its support DDR2 only. AM3 cause it support AM3 poccies. if u want a mobo which support DDR3 only, check for AM3 mobos. however keep in mind AM3 won't support any AM2+ proccy. cause of pin incompatibility.
