Old 26-04-2010, 09:45 PM   #1 (permalink)
happy17292's Avatar
Thumbs down which is better ?? pentium 4 [2ghz] or celeron D [2.4ghz].. for playing old games??
i have 2 processors [socket 478]
pentium 4 2.00GHz
512KB
400MHz
celeron D 2.4GHz
256KB
533MHz
i play old games released between 2001-2007 on this. currently i am using celeron D.
my specs :
processor : celeron D [above]
mobo: MSI p4mam2-v
RAM-768MB
gfx card: Geforce FX5500
i want to know that should i use that pentium 4 or keep using celeron D???
i know this rig sucks. i will assemble new PC next year after my 12board exams.
so please recommend one of above 2 processors which performs better
happy17292 is offline
Old 27-04-2010, 10:52 AM   #2 (permalink)
Wise Old Ghoul
Piyush's Avatar
Default Re: which is better ?? pentium 4 [2ghz] or celeron D [2.4ghz].. for playing old game
^^2nd one seems a lil better
Piyush is offline
Old 27-04-2010, 02:30 PM   #3 (permalink)
laborare est orare
Cilus's Avatar
Celeron D is a better processor. Celeron dos not specify any specific type of processors. It is actually the renaming of the old lot of processors by Intel as a business strategy. Celeron D is the 1st generation of Pentium D processors,
which is actually 2 Pentium 4 (HT) processors are placed in a single package.
They are developed in 90 nm SOI and have large heat generation, compared to the 65 nm or latest45 nm Pentium D processors.
So it will have better performance than a single core P4
Cilus is online now
Old 27-04-2010, 11:52 PM   #4 (permalink)
happy17292's Avatar
i dont think celeron D is renamed old processor.
celeron D [Prescott-256] was based on Prescott Pentium 4 core.
and other one pentium 4 is older northwood pentium 4
so please tell me only when u 'really know' about it
older northwood pentium 4 or prescott 256 celeron D???
Old 28-04-2010, 12:19 AM   #5 (permalink)
Since you have both the processors with you, just try them and see, thats the best way.
mehrotra.akash is offline
Old 28-04-2010, 06:54 AM   #6 (permalink)
happy17292's Avatar
OK. but is there software or test which can tell which is faster??
should i note down time taken by each processor to compress a 50mb file?
or similar movie encoding test?
Old 03-05-2010, 10:52 AM   #7 (permalink)
Depends on what you want to use it for.
If its gaming then use the benchmark for that particular game,if it is encoding videos then test with a 5min video file,etc.
In daily use there will not be much of a difference between the 2
Old 09-05-2010, 06:28 PM   #8 (permalink)
happy17292's Avatar
thank you! i will try
Running Normal Res Games in Widescreen Res (OLD DIGIT SOLUTION) Arun the Gr8 Gamerz 2 25-04-2010 01:40 AM
Games Of October tarey_g Gamerz 10 07-10-2005 06:19 PM
Gamers Are Spending 700 Dollars a Year on Games, IGN Study Sourabh Gamerz 7 30-03-2005 12:40 PM
- by c4u
