Old 26-04-2010, 12:14 PM   #1 (permalink)
Thumbs up Need final compatibility confirmation for 1st PC build!
Hi everyone. Don't know much about computers , so i am asking for you guys to help me out................This is my 1st PC build.
My budget 30k to 35k. (I cant go over 35K, so i want a budget PC)
I got the cost from Amazon and Newegg websites. I converted Dollars to INR. But i am not buying it online, i live in Bangalore and intend to buy in SP Road. Does it cost the same in SP Road. If the cost differs could someone post the correct cost.
Mouse and Keyboard USB Mouse and Keyboard from Logitech ---- 1k
HDD 500GB Western Digital Hard Disk 7200 RPM ---- 2.7k
http://www.amazon.com/Western-Digita...2262673&sr=1-1
DDR3 Ram Kingston 2x2GB 240Pin Long-DIMM DDR3-1333MHz Unbuffer Non-ECC CL9 Value RAM KVR1333D3N9/2G ---- 2.5k
http://www.newegg.com/Product/Produc...R1333D3N9%2f2G
DVD Rom/Writer LG GH24NS50 DVD Writer SATA ---- 1.2k
http://www.newegg.com/Product/Produc...=LG%20GH24NS50
Processor AMD Athlon II X4 620 2.6GHz ---- 4.4k
http://www.newegg.com/Product/Produc...-704-_-Product
Main Board MSI 785GM-E65 ---- 4.1k
http://www.newegg.com/Product/Produc..._-Product#spec
Graphics Card Sapphire Radeon HD 5570 - 1 GB DDR3 HDMI/DVI-I/VGA PCI-Express Graphics Card 100293L ---- 4k
http://www.newegg.com/Product/Produc...-874-_-Product
UPS APC BR550CI-IN 550VA UPS ---- 3k (There is a lot of power cut in Bangalore these days)
http://www.apc.com/resource/include/...sku=BR550CI-IN
Power Supply Corsair 550VX Power Supply ---- 4.2k (Is 550VX overkill, should i go for 450VX or should i go for more 650TX)
http://www.newegg.com/Product/Produc...orsair%20550vx
Cabinet Can anyone suggest a good build ATX Mid Tower Chassis/Cabinet. Budget 2k
Monitor Viewsonic VP720b LCD 17 inches (I already have the monitor)
http://www.newegg.com/Product/Produc...-379-_-Product
It is a Viewsonic VP720b. It has DVI-D but no HDMI.
My LCD monitor only has a resolution of 1208x1024.
I am thinking about buying Sapphire Radeon HD 5570 100293L.
Is my Graphics card and LCD monitor compatible.
Will i be able to watch HD content movies and play games at a good resolution.
Is this combination good? Or any changes required?
By The Numbers is offline
Old 26-04-2010, 05:55 PM   #2 (permalink)
Default Re: Need final compatibility confirmation for 1st PC build!
Here goes ur budget pc under Rs. 35000 .
Processor:- amd athlon II x4 620 - rs. 4800
Motherboard:- biostar TA785G3 HD - rs. 4300
RAM:- kingston 2gb ddr3 1333 mhz. - rs. 2500
Graphics card:- sapphire radeon hd 5750 - rs. 7000 approx.(dnt knw the current price)
HDD:- seagates barracuda 7200.12 500gb - rs. 2300
Optical drive:- LG DVD WRITER for rs. 1100
PSU:- gigabyte superb 460w - rs. 2200
Cabinet:- nzxt gamma - rs. 2000
UPS:- APC 550VA - rs. 1900
TOTAL Rs. 28100
The graphics card u selected is not good for playing games. As u have already have a 17" monitor, the suggested graphics card will run ur games on high settings at 1280 x 1024.
Also one more thing, if ur budget of rs.35000 is without considering the monitor then, change the processor to amd phenom II x2 555 BE for rs. 5100 , motherboard to MSI 785g e53 for rs. 5500 AND PSU to corsair vx450 for 3800 &
also add another 2gb ram stick.
TOTAL will become rs. 33700.
You can unlock the processor to a phenom II x4 or atleast x3....
MUST VISIT..
www.developandshare.com
maddu5731 is offline
Old 26-04-2010, 08:22 PM   #3 (permalink)
Wise Old Ghoul
Piyush's Avatar
@By The Numbers
whats ur basic requirement ?
Piyush is offline
Old 26-04-2010, 10:18 PM   #4 (permalink)
you done good research but the pricing is wrong.
TOTAL Rs. 28100
nicely done
however change PSU to Corsair CX400W. much better. cause i doubt Gibby wil be able handle Phenom II X2---(unlock)--->Phenom II X4 + HD5750. ok, heres the config i feel good for OP:
Processor: AMD Athlon II X4 630: 5k //Phenom II X2 555 3.2GHz B.E if u can find//
Motherboard: Biostar TA785G3 HD: 4.3k //MSI 785G-E53 @ 5.5k, if purchasing X2 555, else no//
Ram: Transcend 2 X 2Gb DDR3-1333Mhz: 5.4k
Hard Disk: Western Digital 500Gb Blue: 2.3k
Graphics Card: Sapphire HD5670 512Mb Arctic Cooler: 5.2k //Sapphire HD5750 1GB GDDR5 @ 8.2k, only if u got monitor upgrade plans//
Optical Drives: LG GH22NS50: 1.1k
PSU: Corsair CX400W: 2.8k
Cabinet: NZXT Gamma + 1X120mm fan: 2.6k //add a good 120mm fan for better air circulation. i prefer Xigmatek CLF 120mm white LED fan//
Keyboard Mouse: Logitech Internet Pro Desktop: 0.6k
UPS: APC BACK-UPS ES 650VA: 2.8k
total: ~32k in getting the one simply mentioned.
Sam is online now
Old 26-04-2010, 11:26 PM   #5 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
^+1 Much better config than yours. Go for the 555BE rather than 630/620. Most 555BE's can be unlocked(I hope you know that).
Well....Now you have 3k left. So I'd suggest to utilize that by going with Corsair VX450 PSU. Though at this config you won't need it. But I'm considering it for your later upgrades.
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 26-04-2010, 11:50 PM   #6 (permalink)
add to it, one getting 5years rebate on tension on his/her PC's health, which are mostly caused by bad PSU rather than entry level mobos/proccies, which most peoples point out.
Sam is online now
Old 27-04-2010, 06:44 AM   #7 (permalink)
Arrow Re: Need final compatibility confirmation for 1st PC build!
Thank you for replying.
But tell me why is the graphics card not good?
Is it because my LCD monitor is old and not compatible with the graphics card or because the graphic card i suggested HD 5570 is not a good card.
Originally Posted by piyush120290 View Post
@By The Numbers
Light gameing, a littile bit of photo and video editing.
I had no idea that 555BE's can be unlocked.
I goggled it and read about it.
Unlocking the cores that is advanced user stuff, i don't know much about overclocking so it is not for me.
I read that the only diffrence between AMD Phenam II x4 and AMD Athlon II x4 is the L3 cache. I am not a power user, it wont make much of a diffrence to me.
My best buddy can relate to that. He once had a P4 system die due to a bad PSU.
I figured the pricing would be wrong.
I don't plan to upgrade my monitor, at least not in the near future.
So does that mean me investing in a graphic card at this time is a waste.
Or is there still hope cause my monitor does have DVI-D, so i guess i can connect the graphics card to that.
My question is will it work. Will it display HD videos and what kind of video resolution can i watch on my current LCD monitor? For example 320p, 720p, 1080p....... will i be able to watch these HD displays.
THX Guys for helping me out.
Decided
Processor
: AMD Athlon II X4 620 if not available 630. 5k
Main Board: MSI 785G-E53 5.5k (Sorry Bio Star, never heard of it)
HDD: Western Digital 500Gb Blue: 2.3k
Keyboard/Mouse: Logitech Internet Pro Desktop: 0.6k
Undecided
Graphics Card: Sapphire HD5670 512Mb Arctic Cooler. 5.2k
@Sam.Shab
Can you point out the Model number of this card or post a link so that i can have a look at the exact specs....... And also instead of 512MB is there a HD 5670 DDR3 1G? Does the performance vary a lot between 512MB and 1GB?
PSU: I think i want to go for a Corsair 550vx PSU. Just to be safe. Can someone get me the cost of this PSU.
DDR3 RAM
: I would love to go for Kingston. Can someone get me the cost of DDR3 1333MHz Valur RAM from Kingston.
Old 27-04-2010, 09:36 AM   #8 (permalink)
not enough horsepower. also pricing is bad, comes very close to HD5670. which is ~2X more powerful. moreover u got a 17" display. so a HD5670 should suffice.
not advance at all. simply turning on a option in bios wil unlock it. simple. moreover if some help needed, TDF always there.
well u right. Athlon II's are for normal usage. Phenom II's add more horse power. so its upto u. do u really need extra horsepower. are u power user? gamer? if yes, Phenom II, X4 specially will help. else stick to Athlon II X4 or Phenom II X2 (bargain considering it will unlock to X3 or X4, free of charge).
result of buying el chepo PSU.
not waste. buy it now only. however buying a very high end card that when a upper lowend is good, is a bad decision.
if u simply want watch video, IGP should be able handle. however a addon card will take load off your proccy. also HD5670 is more than u need to watch HD movies. however it is currently very good value in 5k segment.
Decided
Processor
Biostar is a good company & are boards are usually priced very nicely. however if u can get MSI's 785GM E53 within your budget & also getting a graphics card, i see no particular reason look at bio*.
also try get X2 555 BE (not 550 BE). else get X4 630. X4 620 & 630 pricing very close. so opt for 630.
Undecided
@Sam.Shab
SAPPHIRE HD 5670 512MB GDDR5.
the performance difference between 1Gb & 512Mb too less to spend extra 1k or so for extra memory. cause HD5670 not enough powerful to utilize all the 1Gb GDDR5 memory. half of it will be sitting idle. also i suggested Sapphire cause of its cooler. it got a Premium Arctic cooler. will keep card cool even on hot summer days & pricing is lower than others (spell double bargain)
DDR3 RAM
VX550W too much for your rig. even CX400W will be enough. get VX450W. its very good value & can power your rig even with a more powerful card & proccy.
Sam is online now
Old 27-04-2010, 10:18 AM   #9 (permalink)
Wise Old Ghoul
Piyush's Avatar
@sam.shab
1 dumb question that keeps hitting me
how do we know that "this" graphic card will be able to use its 1 gb memory or not?does it depends on its clock rate?or number of ALUs?
@by the numbers
go for vx 450W , its enough and good
regarding gfx card,opt for hd 5750(much better option for ur future)
rest of all seems cream!!
Piyush is offline
Old 27-04-2010, 11:16 AM   #10 (permalink)
@sam.shab
i don't see it to be dumb question from any angle. actually well laid out problem.
actually theres many things to consider:
1. SIMD. too less SIMD to keep all memory busy. most suitable card to use 1Gb full memory is HD5770. it got right balance of power & memory. its like transporting a TV from shop to your house. u not need truck for that task. a car/van will do just fine.
2. bus width. 128bit enough for lower midrange cards. cause they not need transfer lots of data. u can put a HD5670 in a 512bit bus but at most u'll have a performance gain, u won't feel until u start counting each frames. add to it, more bus width, cost of GPU will go up. its similar to the above example. u not need a 4 lane highway for your local colony. a single street road enough. got my point?
also less memory, cooler & cheaper & less power consuming graphics card.
@by the numbers
he can't opt for HD5750. it'll be out of his budget & also he not avid gamer. so HD5670 will be good enough i feel.
Last edited by Sam; 27-04-2010 at 05:07 PM. Reason: written TB instead of TV. oops.
Sam is online now
Old 27-04-2010, 04:53 PM   #11 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^yup
nice examples anyways
Piyush is offline
Old 28-04-2010, 10:14 AM   #12 (permalink)
Talking Re: Need final compatibility confirmation for 1st PC build!
Thanks guys.
Really appriciate all your help.
Final build
Processor: AMD Athlon II X4 620 if not available 630. 5k
Keyboard/Mouse: Logitech generic USB Keyboard and Mouse: 0.6k
Cabinet: NZXT Gamma + 1X120mm fan: 2.6k + 0.5k
Graphics Card: SAPPHIRE HD 5670 (Redwood) 512MB: 5.2k
http://www.newegg.com/Product/Produc...-871-_-Product
Ram: Prefarably Kingston if too pricy Transcend 2x2gb: 5k
PSU: Corsair 450vx: 3.8k
Philips Headphones:0.5k
Total: 35k
One last question Do i need a CPU cooler for this above config? Or will the stock cooler do the job.(I don't plan to overclock the system)
http://www.coolermaster-usa.com/prod...roduct_id=2923
http://www.amazon.com/s?ie=UTF8&inde...&tag=smtfx1-20
Old 28-04-2010, 10:45 AM   #13 (permalink)
Wise Old Ghoul
Piyush's Avatar
Thanks guys.
not really
athlon II runs cool on the stock cooler
Piyush is offline
Old 28-04-2010, 05:12 PM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
help me dosto..
Basic Guide Purchase a New System
Piyush is offline
Old 28-04-2010, 06:13 PM   #15 (permalink)
not again.
Sam is online now
Help me restart pbm aravind.gslv QnA (read only) 1 06-05-2008 01:30 AM
Win XP SP3 Final (Expected this week) Yoda Technology News 9 20-03-2008 08:43 PM
BioShock demo is not working in my pc the.kaushik Gamerz 27 17-10-2007 07:17 PM
SimCity 4 crashes and restarts system!! hearthacker Gamerz 2 28-03-2007 11:02 PM
Problem with POP:WW Plz help!!! anubhav_har Gamerz 11 21-08-2006 10:55 PM
- by c4u
