Old 25-04-2010, 08:10 PM   #1 (permalink)
Default Laptop Problem
I have a Laptop with config- Core 2 deu Processor, 2.00 Ghz, 2GB Ram, 320GB HD from Zenith. I have a strange problem- A Green line is sparking horizontally over the task bar of my desktop. I have consulted with the company as it was under warranty and they have changed LCD. At first the problem is gone, but after three days the same line again started to spark at the bottom of my desktop. I have also formatted my hard disk and used Windows Vista Business. But no solution. The line started to spark constantly in seconds whenever I play video from my HD, but other wise it sparks after 1-2 minutes. Can anyone suggest solution?
rborahsbi is offline
Old 05-05-2010, 06:50 AM   #2 (permalink)
Default Re: Laptop Problem
I can suggest you three things-
1. Update your graphics driver
2. Try using a different or less system hungry operating system
3. Also do check your line voltage regulation since the display showed the same problem again after repair. That may be the real cause.
sanderz178 is offline
Problem viewing usage abhijangda Chit-Chat 4 04-04-2010 01:08 AM
100% cpu usage problem anant197 Tutorials 2 03-04-2010 01:36 PM
Laptop Cooling Pad-Help this out joey_182 Hardware Q&A 6 24-03-2010 11:53 AM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
- by c4u
