HI
my current configuration is
processor - Intel core 2 duo E4500 2.20 GHZ
motherboard - intel essential series D945GCPE
i wish to change my motherboard as it is giving problem and it does not have slot for using graphic cards.
Also my power supply unit is busted. so need a new one which can support my 250 + 500 GB internal hard disks as well as a graphic card.
my budget is
for motherboard .. 3000-4000 Rs.
Power supply unit .. 1000-1500 Rs.
Graphic card .. 5000-6000 Rs.
Please help
and also, Dx11 compatibility depends on motherboard also or only Graphic cards.
please reply soon. thanks!
