24-04-2010, 12:03 AM
Worth buying i7 ??
Presently, I am on P4 3.0ghz and want to upgrade my system.
I am thinking of upgrading to i7. Is it worth upgrading as I am not into gaming at all.
Also tell me..Is capturing screen video..good config is required ???
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
24-04-2010, 01:11 AM
Super Moderator
Re: Worth buying i7 ??
What you mean by Capturing screen video. Not that you did not state is correct, not aware of the technology.
24-04-2010, 12:28 PM
Wise Old Ghoul
capturing screen video???
can u please elaborate it?
24-04-2010, 02:21 PM
Reverse Engineering rocks
I think he means that he has to record on-screen happenings...
It can be done with the help of the software called Fraps...
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
24-04-2010, 04:21 PM
however trial version is useless. only 30-45sec or so recording allowed.
24-04-2010, 05:46 PM
Why don't you wait for the new HEXACORE amd x6 processor ...... If Ur not eager to buy sooner.
As it's latest tech of Intel people are still working on the exact Benchmarks.....
So i suggest you to wait or buy an core i5
ASUS M4A78EM/1394 | AMD 720 X3 | ADATA 2GB | IBALL 450WATT | IBALL i612 | TVS GOLD | IBALL 800dpi | WIN XP | SAMSUNG LCDTV 550 32" | HDD 160GB + 320GB
25-04-2010, 02:42 PM
Bro do u know any other software(preferably freeware) for on-screen recording coz i want to use it to record my gameplay in the games.....????
25-04-2010, 10:38 PM
Capturing embedded videos on site.
---------- Post added at 10:38 PM ---------- Previous post was at 10:36 PM ----------
I want to capture Embedded videos...so that I can play it w/o connecting to net.
I tried to capture but the problem is video is playing very slow (frames)
25-04-2010, 10:57 PM
till now i not came up across any such software  i myself used & liked fraps. only didn't liked the trial version capture time too much short.
26-04-2010, 12:13 AM
I agree....But do tell me when u come around any such software...!!
26-04-2010, 09:49 AM
Super Moderator
I still do not understand what the OP wants to do.
26-04-2010, 10:42 AM
Wise Old Ghoul
^^same here
26-04-2010, 01:15 PM
lol...I tried FRAPS and it works for me.
But NOW
Problem is : Fraps consuming large amount of space ...just for 45 min video (.avi format)...12.5GB
and saving the file in parts (arnd 15min each)
Is there any other software similar to fraps...??
26-04-2010, 08:55 PM
Who stole my Alpaca!
Hi there,
Being a past MMORPG Gamer I used to take videos of our Raids in Everquest. SO I think I could probably help out with this question.
For capturing videos in game you can try out the following software.
Fraps
Camstudio
Xfire (Doesnt Xfire have a tool you can record videos with?)
Growler Gun Cam
DM Game Capture ? (Something similar forgot name sorry)
There might be many more but usually people are satisfied with Fraps , Xfire or Camstudio.
If you are talking about recording videos on web pages then you can view most by simply opening your temporary folder and copying the files to a folder. Although there are quite a few plugins for browsers etc which will do this for you.
26-04-2010, 09:08 PM
Thanks filledvoid...
Will try out the mentioned softwares and post.....
27-04-2010, 10:48 AM
Wise Old Ghoul
oh.. yeah
i remember now
there used to be a software called Xfire and fraps
i've tried fraps
and it works all right
got 1 in a SKOAR DVD
27-04-2010, 08:27 PM
Using Fraps....I recorder 2hr video...
Video recorded at 8-10fps and took "approx.32 GB" space.
How can I reduce the size without loosing quality (as far as possible)?
Is there any similar software which can do the same job but take lesser amount of space.
Also...this 2hr video is recorded in segments (3.90 each).
27-04-2010, 09:10 PM
Hmmm I think I noticed this thread containing information about this . Ill link it here .
As for the rest. Read Fraps FAQ and you will understand why you get that size and what you can do to fix it. Heres an excerpt taken from it.
Why is the AVI movie generated by Fraps so big? How can I reduce the size?
The filesize is big because there isn’t enough time to encode the movie while the game is running. The movie frames are slightly compressed, but still require a large amount of disk space due to the high resolutions. Once you have finished capturing you should convert the saved AVI into one of the popular compressed movie formats such as mpeg or divx. Recommended programs for doing this are tmpgenc (Tsunami Mpeg Encoder), and VirtualDub.
Using VirtualDub is quite easy. To create a compressed version of the AVI follow these steps:
Start VirtualDub
Select File->Open and choose the AVI in the Fraps directory you wish to compress.
Select Video->Compression and choose the codec you wish to compress with (usually divx)
Select File->Save As AVI and specify a filename for the new AVI.
If you have Windows XP you can also use Windows Movie Maker to compress the video files. If you use Windows Movie Maker it's recommended that you keep your Fraps video files at 800x600 or under.
Source
29-04-2010, 11:13 PM
#19 (permalink)
I captured video using Fraps but don't know why it saved in parts (3.90gb each).
And I converted it to .mkv format and then try to join it with mkvmerge but can't able to. Please suggest other mkv file joiner.
29-04-2010, 11:53 PM
#20 (permalink)
try Format Factory. using it u can convert to any popular video format in books. also got provision to add videos. download it from here. not sure if u'll like it but you can join the videos.
30-04-2010, 12:49 AM
#21 (permalink)
BLUE IS THE COLOUR
There is an option in Fraps to select half size or full size.Select half size it will reduce the capturing resolution 50% and many GB's are saved.I usually record my games using Fraps.Then I convert it to Xvid avi.A 1GB file can be converted to 30-45 mb's in good quality with in minutes(thanx to X4)
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
01-05-2010, 06:57 PM
#22 (permalink)
But why the video captured in parts ??
01-05-2010, 07:08 PM
#23 (permalink)
BLUE IS THE COLOUR
I havnt experienced this problem.Since the file size is 3.90 I guess your target partition is FAT32 it cant support single files with size higher than 4GB.So its automatically split at 3.9GB.But I am not sure its only a guess.
01-05-2010, 10:51 PM
#24 (permalink)
Partition is NTFS !!
02-05-2010, 12:23 AM
#25 (permalink)
Yes I had this problem and unfortunately there isn't a way around it I believe. Its something to do about incompatibility of other Video Players or other software. Initially I also thought it had something to do with the File system being used or the OS being used but it turned out it wasn't.
02-05-2010, 09:01 AM
#26 (permalink)
Suggest me best .mkv joiner...
I tried mkvmerge...but can't able to join.
02-05-2010, 09:41 AM
#27 (permalink)
bringing the world down
use fraps, it is good even for spying on shared systems, and core i7 is good
