Old 23-04-2010, 02:06 PM   #1 (permalink)
mdp
Default How to use BSNL broadband landline modem when there is power off..?
Hi friends..
I am planning to purchase laptop due to 7-8 hours of load shedding in my city.
I will use laptop in office and will require inter net continuously..
I have BSNL landline modem presently.It requires 12V DC power supply.
In case of power failure how can i use net..?
is there any kind of adopter available in market which will take power from USB of laptop and will convert to 12 V DC and can be used to power up modem..?
Any other way..?
YOUR PLANS MAY FAIL, BUT DON'T FAIL TO PLAN...
mdp is offline
Old 23-04-2010, 02:51 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: How to use BSNL broadband landline modem when there is power off..?
BEST WAY.. i can think of is BUY A UPS/
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 23-04-2010, 05:04 PM   #3 (permalink)
Get A Solar Panel?
Aspire is offline
Old 23-04-2010, 09:23 PM   #4 (permalink)
sriharsha_madineni's Avatar
Back-up UPS is a good option as said above
[Intel E8400]+[Intel DP35DP]+[4GB DDR2]+[GTX 560Ti]+[Corsair VX450]+[Altec Lansing VS3251R 5.1]+[DELL S2409W]+[Logitech MX-518] [iPod Touch 32GB] [iPhone 4 16GB] [Galaxy S II] [Sony Vaio EB26]
sriharsha_madineni is online now
Old 23-04-2010, 11:49 PM   #5 (permalink)
@OP
I too had same idea of powering modem from USB.
There was huge thread on it. Have got solution of powering Airtel Modem from USB
PraKs is offline
Old 24-04-2010, 05:34 AM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
Theoretically that would not work, because USB is a 5v source. 5v-to-12v step up adapters may work but I don't think the current requirement is satisfied (500mA is the max. and the modem would definitely require more). In short, I would refrain from doing this.
I would anyday, got in for cheap UPS to power the modem. Since the modem/router consumes quite low power, you can get like 4-5 hours (or even more) backup for your modem.
infra_red_dude is offline
Old 24-04-2010, 11:49 AM   #7 (permalink)
mdp
I have 600VA Wipro (WEP) UPS.How long it will last?
can any body answer who practically uses modem on UPS..?
why does BSNL dont introduce modems running on 5V USB power supply..?
to whom should I give feedback in BSNL..?
mdp is offline
Old 24-04-2010, 12:59 PM   #8 (permalink)
Wire muncher!
It doesn't matter. Just a search for 5V modems gives a current requirement as 2.0A which is too high. This kind of current can never flow through USB. That's 4 times the max. current (500mA). The max. wattage supplied by your USB is 5V * 500mA {or 0.5A} = 2.5W (roughly). Most modems have a power rating of a minimum of 7W. So your USB port cannot supply enough clean power.
Old 24-04-2010, 01:27 PM   #9 (permalink)
@infra_red_dude'
There are people who claimed that Airtel modem works by powering from USB port.
I guess its 220BX version which takes 5v power.
PraKs is offline
Old 26-04-2010, 12:40 AM   #10 (permalink)
Wire muncher!
Originally Posted by PraKs View Post
@infra_red_dude'
You may check out the current rating of the modem before you plug into the USB port. End of the day you want to use the modem during power cuts, but if the modem itself sucks too much power from your laptop then the whole purpose is defeated!
I believe you can use a Y-USB cable for more power (they are in parallel; remember Kirchhoff's Laws? currents in parallel get added)
Old 26-04-2010, 10:59 AM   #11 (permalink)
Living to Succeed
ajayashish's Avatar
i think for one the modem powered by USB comes out... people will ask for modem which dont need any power as well... Crazy people always needs new things to make their life easier...
Even if u power ur modem with USB you will drain ur laptop battery... which in turns shorten the battery life... i think... UPS is cheaper than a Laptop battery
Old 26-04-2010, 04:48 PM   #12 (permalink)
@ajayashish
Techie wishes are never over
Idea is to keep modem on for 10-30 mints by taking power from USB/Laptop battery.
I guess it will not be much problem when other USB devices like ext HDD/mouse are not connected.
@infra_red_dude
Can you post pic of Y-USB cable ? Any idea what rating Airtel 220BX requires ?
PraKs is offline
Old 26-04-2010, 06:55 PM   #13 (permalink)
Section Moderator
gopi_vbboy's Avatar
why dont u get a inverter for home
i have a 130AH battery -800VA inverter...connected to all lines exept fridge,a/c,heater,etc heavy loads....
so go for inverter with dedicated wiring at home
gopi_vbboy is online now
Old 26-04-2010, 10:09 PM   #14 (permalink)
Its Best only if its open
ankushkool's Avatar
I use my moden on ups, althoigh i m using tikona... but 7-8 hrs... is it at once or in intervals?
ankushkool is offline
Old 26-04-2010, 10:25 PM   #15 (permalink)
Well Inverter costs 10000 Rs
UPS costs around 2000 Rs
USB Cable costs 100 Rs...
Make your choice
PraKs is offline
Old 26-04-2010, 10:41 PM   #16 (permalink)
6x6
half way there
6x6's Avatar
if you have to run only modem from UPS, better option is to take out 12V DC from battery terminals, and keep the UPS off. it will run Modem for ~10 Hours. as modem needs 12V@0.7A and UPS battery is 7AH. no need to step up from 12V DC to 220V AC and then step down 220V AC to 12V DC again, power is wasted in both operations.
another option is using small 12V battery with small charger, setup may cost <Rs500/- and backup time will be 2-4Hours depending on AH capacity (naturally battery cost will also depend on AH capacity)
Intel C2D | G31 | 2GB | 320GB
6x6 is offline
Old 27-04-2010, 10:51 AM   #17 (permalink)
Wire muncher!
@infra_red_dude
http://www.toshibadirect.com/images/...a82010-300.gif
Absolutely no clue about the power requirement of any modem/router!
I would never do that. Without a regulator circuit I would never connect anything to the bare battery terminals.
Old 27-04-2010, 02:11 PM   #18 (permalink)
@6x6
Uh, looks too scientific, it may blast modem too, Why would someone risk taking battery out of UPS & connect openly.. It will look like garage in home
Anyone interested in powering up Airtel modem using USB port of laptop ?
PraKs is offline
Old 29-04-2010, 12:51 AM   #19 (permalink)
icebags's Avatar
wrong..... the 12 volt battery can supply ~12v max with constant DC supply. there should not be any problem running a 12v modem from the 12V storage cell, since there is no current fluctuation from battery, just constant voltage decay from 12v to downwards .. which should last ~8 hrs before the battery fails to supply required voltage for modem ..
then only the situation may go wrong.... modem components may heat up a lil / do malfunction stuff cause of low voltage.
its good choice to run 5v modem from a 12v storage cell, driven by a simple 5v voltage regulator from class 12 physics book tho.
icebags is online now
Old 30-04-2010, 12:47 AM   #20 (permalink)
Wire muncher!
It's not like it will blow up the appliances. I would still never use anything directly without a regulator. Connecting appliances directly to local batteries is the last thing I'd want to do!
Old 30-04-2010, 06:21 AM   #21 (permalink)
Even thought the battery when directly connected will provide a backup of 2-4 hours to the modem, what about the backup for laptop??????????
Depending on the company and batterys health the back up can be anything. SO better use a UPS, to directly connect to laptop and modem both, so that when laptop battery begins to run out of juice the UPS can juice it up. Also do check before buying UPS, because some companies make their UPS as such that if there is no good amount of power drawing from it it will shutdown, I had one in my friends home, whenever he ran only Modem in his UPS it used to shut down automatically but when he connected PC n modem both to UPS it worked fine for the 20 mins or so. He told since the Modem draws very less power the UPS thinks there is no device drawing power from it and autoshuts down, thinking UPS eh :-P:-P
rsk11584 is offline
Old 03-05-2010, 07:27 PM   #22 (permalink)
Buy a 12V Battery (SUNCA) and Compatible Charger for it. Battery will cost you around Rs.200. Configure it and It will give u enough backup for your modem.
deepak2010 is offline
Old 04-05-2010, 09:55 AM   #23 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
I agree with deepak...being a techie you should not be afraid of doing experiments...moreover it does not affect any instrument/gadget, it is the best and cheap option. I have made many small scientific projects during my school days using such setup...hardly broken anything...
My personal blog - http://gagan.scholarguru.com
gagan007 is offline
** Post all your BSNL Dataone Related Queries Here ** drgrudge Broadband and DTH 4591 28-05-2012 07:43 PM
The ultimate modem reset tutorial for bsnl home 500(or any other connection) blademast3r Tutorials 6 05-05-2010 06:56 AM
Steps to take before migrating to BSNL wi-fi modem ayushman9 Software Q&A 2 03-10-2009 09:33 PM
BSNL Modem MT880 Replacement Charan Hardware Q&A 3 11-09-2009 09:33 PM
- by c4u
