Old 22-04-2010, 10:45 AM   #1 (permalink)
Question DVD Writer Help
Dear Friends,
I am using a HP DVD Writer (model: dvd635i). Last few days it refuses to burn any dvds. i tried various dvds. but nothing helps. please help me what should i do. warranty period has been over.
Also if i want to buy a new dvd writer, then can u please help me to choose the product. which dvd writer should i buy?
please help me!
Suman Ghosh
sumangh01 is offline
Old 22-04-2010, 11:11 AM   #2 (permalink)
change is constant!!
khmadhu's Avatar
Default Re: DVD Writer Help
whats the error u r getting..?, which software r u using..?.
try various software instead of various DVD's
keep this as u r last option.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 22-04-2010, 11:21 AM   #3 (permalink)
i already used Nero 7 & 9 and imgburn. all software fails to burn dvds. nero shows error " This process can not be completed" and imgburn shows error" finalization error: track mismatch"....
Suman Ghosh
Old 22-04-2010, 02:44 PM   #4 (permalink)
khmadhu's Avatar
try burning with less speed like 4x or 8x, r u sure u r using good brand DVD's.?
also u can try with other OS's if u have installed, like linux, win7/xp etc..
since when u r experiencing this problem..?
khmadhu is offline
Old 22-04-2010, 04:00 PM   #5 (permalink)
How old is your current DVD writer?
if it is more than 2-3 years old then perhaps it has gone bad, but do what the others have advised you on this forum.
Try different versions of Nero beginning from version 6, personally i still use Nero 6.6 on my system running Windows XP Professional as i find it to be very stable.
Next, try a decent brand of recordable media such as Moser Baer or Sony.
i use Moser Baer Pro DVD-R recordable media.
let us all see the "i" in the "u".
insaneYLN is offline
Old 25-04-2010, 09:50 AM   #6 (permalink)
hi insane,
my dvd writer is 4 year old and after trying all the possibilities i choos to buy a new one. I bought LG dvd writer @ 1120/ rupees with sata cable.
thanks to all support.
Suman Ghosh
Old 26-04-2010, 01:48 PM   #7 (permalink)
prvprv's Avatar
Try to burn the disks at the least possible speed.
It worked for me also.
C2D E7200, Gigabyte GA G31M S2L, 2*1 GB Transcend RAM @ 800MHz, 1TB Seagate 7200.12 + 500GB Seagate 7200.12 SATA + 80GB Seagate Barracuda , LG DVD RW @ 22x, BenQ G2220 HD
prvprv is offline
How to rip DVD and convert Video to iPod popularscan Tutorials 1 24-11-2007 06:16 PM
Dvd Writer Buying Guide????? dinesh_mettur QnA (read only) 1 12-11-2006 08:35 PM
DVD Writer not writing DVDs, Please help Anurag A Hardware Q&A 2 01-09-2006 06:29 PM
- by c4u
