Old 21-04-2010, 10:52 PM   #1 (permalink)
Default Motherboard-Intel or other
What is the advantage,if any of going with a 3rd party motherboard like Gigabyte,etc rather than going with Intel, if the computer is not going to be used for overclocking?
mehrotra.akash is offline
Old 21-04-2010, 11:03 PM   #2 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Default Re: Motherboard-Intel or other
Intel mobo's sucks....Rather go with Gigabyte, ASUS, MSI, Biostar etc(I prefer them in the same order)
And the main point I think is the servicing is far better in case of so called 3rd party
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 21-04-2010, 11:06 PM   #3 (permalink)
Any specific reason you say that Intel mobo sucks?
cause both my previous machines were based on intel mobo's
sold the 1st one(P2) off in 2005(worked for >5yrs) and bought a p4(Still working)
looking to upgrade to an i5..
Old 21-04-2010, 11:23 PM   #4 (permalink)
Simply a DIGITian
Yup you are right. Even I'm using Intel D945G mobo. But the days are gone. Intel mobo's keeps failing nowadays(I mean newer ones). Just keep your eyes open and see the threads in this forum. You can read reviews too.
And as I said the servicing(RMA and all others) that matters most. In that area intel sucks.
Well for i5 I would like to recommend to go with MSI P55 GD-65, It's a gr8 board(VFM).
Old 21-04-2010, 11:36 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Mehrotra.akash:
You question is far to generic -- to get a specific answer. You have to mention which chipset/CPU 'class' you are interested in. It is like saying is Maruti better or Hyundia. Both are leaders/average performers in their own sub classes / segments.
In your third post you have mentioned i5. As a general consensus Intel builds did not have OC capability. The BIOS was locked. To conduct OC, you need parameters like vCore, DRAM : FSB ratios, RAM timings changeable. Intel boards had these locked. Thus you could not OC on them. They have now started to release E (extreme) series boards which enable this, but most reviews stated the BIOS as 'difficult to work with'. Intel DP55KG Extreme Series P55 is one such example.
They are not bad boards. If you are doing basic stuff (read non-OC), they are just as fine as Asus/Gigabyte/MSI (alphabetical) boards. Intel service if not less, is at par with the rest of the companies.
asingh is online now
Old 22-04-2010, 12:06 AM   #6 (permalink)
Thx, the approx config i am looking for is
Kingston 2 GB 1300 MHz DDR3 Ram Price – 1950/- x2
Intel Core i5 750 Processor Price in India – 10,500/-
Cooler Master cabinet - 2500
Cooler Master eXtreme Power Plus 500W – 2,800/-
Corsair VX450W @ 3.8k
Intel DP55WB Rs5600
ATI Radeon HD 5750 1GB in India – 8200
For this would you recommend sticking to Intel or going for a 3rd party. This PC will be used for occasional lightweight gaming,else normal stuff but will be using a 22-24 inch monitor.
(Will be making a few changes to the config and consulting this forum again, not final as yet)
Old 22-04-2010, 12:23 AM   #7 (permalink)
Intel DP55WB Rs5600
Kingston 2 GB 1300 MHz DDR3 Ram Price – 1950/- x2 ---> where u getting DDR3 ram for such el chepo price?
Cooler Master cabinet - 2500 ---> get cheaper cabby. 1.6-2k.
Cooler Master eXtreme Power Plus 500W – 2,800/- ---> NO.
Intel DP55WB Rs5600 ---> try get MSI/ECS P55 mobo. cost little more.
ATI Radeon HD 5750 1GB in India – 8200 ---> get HD5670 512Mb or HD5770 1Gb
---------- Post added at 12:23 AM ---------- Previous post was at 12:22 AM ----------
or you talking about 1Gb DDR3 X 2?
Sam is online now
Old 22-04-2010, 12:31 AM   #8 (permalink)
Got the prices from priceindia.in, dont know the accuracy It's 1950 for each stick of 2GB, is it lower than the market price?
Old 22-04-2010, 05:44 PM   #9 (permalink)
local price ranges from 2.5k-3.1k for Transcend 2Gb DDR3-1333Mhz CL9. will be almost same for Kingston also.
Sam is online now
Old 22-04-2010, 06:19 PM   #10 (permalink)
Simply a DIGITian
Well......for the Mobo get MSI P55-GD65 @ 9.5k / Asus P7P55D / Gigabyte GA-P55-UD3R @ 10-11k / Asus P7P55D-PRO @ 12k
For cabby get CM Elite 310 @ 1.5
+1 to Corsair VX450W as recommended by Sam. Don't even think of getting CM's Extreme Power Plus series PSU's.
Get Sapphire HD5770 1GB GDDR5 @ 10k
And for RAM get Transcend 2GB DDR3 1333MHz @ 2.5k
Old 22-04-2010, 06:28 PM   #11 (permalink)
The MSI P55-GD65 seems to have a lot of features targeted towards overclocking, as I will not be using these features at all, is there a cheaper version without the OC options?
Old 22-04-2010, 06:32 PM   #12 (permalink)
Simply a DIGITian
Well.....in that case look at Gigabyte / ASUS
GA-H55M-USB3 @ 7.5k
Gigabyte P55M-UD2 @ 6k (It's a gr8 board)
ASUS P7P55D @ 7k
Old 22-04-2010, 07:24 PM   #13 (permalink)
try this than: MSI P55-CD53. it got 3+1 phase. so not good for OC. Asus got 10+2 phase. however not sure. so is great for OC.
Sam is online now
First look at the Intel D5400XS motherboard PCWORM Technology News 20 14-04-2008 01:07 PM
bios password of Intel motherboard D945GCCR Ramakrishnan CPU / Motherboards 4 03-02-2008 10:34 PM
Intel Price Cut glass Hardware Q&A 117 02-08-2007 12:28 PM
CEBIT 2005: AMD or Intel? Same Motherboard! Sourabh CPU / Motherboards 5 17-03-2005 11:51 AM
- by c4u
